How do you open a session and disable all plugs?
I made a session too large for my system and now it doesn't want to open. I want to disable the plug-ins before I open this session so that I can make some tracks inactive. Anyone know how to do this?
Thanks...
Have a great day..... Bill ---------------------- Mac Mini (2019) 3.2 Ghz - 6 Core i7 Mojave with 64 GB RAM PT Ultimate (2019.10) Motu 16a C/24 Control Surface |
Re: How do you open a session and disable all plugs?
Hold down Shift while clicking Open in the Open Session dialog. BTW, there's a searchable PT Ref guide in the Help Menu.
The shift trick doesn't seem to work from the startup dialog FYI, only with the command+O command.
Are you holding shift whilst opening the session? (not booting pro tools!) Chris
i use the option key while removing send and plug with a global intent
it takes out rows at a time about 8 mouse clicks and your are clean you said "disable"...my suggestion will remove probably not what you meant.
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
Shift plus Double Click the session icon.
That's what I do all the time! It works
http://www.ricardomosca.com Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2023.9.0, SSL 4040G+, tons of outboard Mac Book M1 Pro, 16GB RAM, OSX 23.6, PT Studio 2023.9.0 |
The 'hold shift' trick doesn't seem to work if you get the "this session was saved with a different playback engine" dialogue - whether or not you change the pb engine at that point, it then seems to forget that you held shift.
PT2023.12 - Mac Studio M1 Max 64GB RAM - macOS 13.6.3 - UAD-2 Satellite Octo/Apollo 8tb Duo/Apollo 16ii/Prism Lyra 2 - Euphonix Artist Control - All the plugins(!) Waves/PA/Slate/SSL/McDSP/UAD/Kush/SoundToys/Eventide/Softube/NI/PSP/Sonible/BABY/Fabfilter/Sonnox etc. |
Move those (all?) plugins to your unused folder before booting Pro Tools. The automation will retain but the plugin will show as inactive. PITA was to do it, but it works when there's no other way.
-Ryan Young •2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
PT Plugin Manager http://www.maisonsonique.com/index.p...-software_side Richard
Pro Tools 2023.9 Ventura 13.6 |
song will not open, could not complete the open session commandbecause...while transl | SNAPPER | Pro Tools 9 | 6 | 02-11-2017 11:32 AM |
Disable "Session Notes" pop ups at session start up? | DJ Hellfire | Pro Tools 10 | 1 | 02-05-2012 10:25 AM |
Disable VI's to launch session? | raydsr | Virtual Instruments | 3 | 05-11-2009 12:53 PM |
File won't open, need to disable demo plugin help! | Rockem | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-16-2008 02:08 PM |
KILL/DISABLE ALL PLUGINS: at launch of session? | gollywillickers | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-22-2006 11:28 AM |
