Old 10-22-2017, 12:03 PM
rstreber rstreber is offline
Default Re: clock changes to 192k when I quit PT?
Interesting. Did anyone find a solution, even of changing the "default" sample rate to 96k? I just want to avoid switching over to a 3X rate.
Old 10-22-2017, 01:12 PM
Drew Mazurek's Avatar
Did you try changing sample rate in the audio MIDI set up app?
www.drewmazurek.com
Old 10-22-2017, 02:35 PM
I was having this happen a while back.
I went into audio midi sep up & in there it was set to 192. I changed it to 48 & the issue was resolved.
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 10-22-2017, 07:35 PM
Thanks for pointing me in the right direction, I think that did it! I had actually checked Audio MIDI setup before, but only when Pro Tools was running which meant that the HDX option didn't appear. But I went back with PT shut down, changed it over, and that seems to do it. Thanks!
Old 10-24-2017, 04:39 AM
syMPh syMPh is offline
Default Re: clock changes to 192k when I quit PT? [solved]
I'm a bit late to the party but it does this with my symphony's as well... even though you have discovered that changing core audio fixes it I find that often it forgets that it's been "fixed" and defaults back to 192... I think this is OS/ Core Audio which is the problem . is yours staying put on 48 now you've changed it or are you finding you have to keep updating it every once in a. while?
System Details
Old 10-27-2017, 01:20 AM
martthie_08 martthie_08 is offline
Symphony here, huge PITA problem, as I have 100feet Digilink cables and cannot reset to 44.1 from within ProTools.
In fact, I have to do a full hardware reset on the main (clock master) Symphony IO whenever this happens.
Sometimes I can get it back from within Audio/Midi Setup but not always.
Old 10-08-2021, 03:59 PM
flavor32 flavor32 is offline
I had this just now with my new MTRX Studio where the sample rate reverted back to 192 when quitting pro tools if dadman settings were for the sync to be via digilink. System audio settings did not change it. I found that if I opened the previous Avid Streaming server Coreaudio settings app I used with my Omni, I could change it there and it stuck. It was indeed saying 192khz in that Avid Coreaudio settings software panel. After changing that, all good for now.
McKay Garner
Production/Stereo and Dolby Atmos Music Mixing/Composition
San Francisco Bay/Los Angeles/Web
http://www.mckaygarner.com
Pro Tools 10HD won´t sync to word clock [SOLVED] Simon Johansson Pro Tools HDX & HD Native Systems (Mac) 2 01-31-2016 12:49 AM
Pro Tools refuses to quit. Have to force quit. SD2 Pro Tools 10 13 01-23-2014 08:21 AM
003 R+: Quit PT, open CoreAudio Manager = no sound!! (><) SOLVED UltraNEO* 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-04-2009 11:05 AM
automation quit working on one chnl.. (solved) tim carter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 06-22-2007 08:34 AM
Clock problem solved, but still somewhat unsure ryanstack 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-30-2005 01:29 AM
