Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 10-01-2012, 10:26 AM
nickmadsen nickmadsen is offline
Default "Pre-fading" snare sound
How do you get that snare sound that kind of fades a bit into the "snare hit". It's kind of hard to explain. But it's like when someone uses a whip, and you can kind of like hear the whip through the air before the impact.
I hope you understand what I mean, and I'm sorry if this is described elsewhere, but I don't know the correct term for it. I've searched for things like "snare pre delay" And "pre fade", but can't seem to find anything.
thanks in advance.
Old 10-01-2012, 11:24 AM
Lincoln Mitchell Lincoln Mitchell is offline
Default Re: "Pre-fading" snare sound
I know of a couple ways...
1) take a copy of the snare hit and reverse it. Ten blend to taste.
Then on a separate track line it up so the peak lines up with the main snare transient. Then blend to taste.
2) record a reverb tail from the snare reverb return. Then use the steps above...
Lincoln Mitchell
Pro Tools | latest
Mac Mini Server | OSX | Current
16GB Ram | SSHD
Apogee Ensemble Thunderbolt
Old 10-01-2012, 12:59 PM
Thank you very much. It sounds so easy, and I can't believe I didn't think of that myself.
Gonna play with some snares tomorrow.
cheers
Old 10-05-2012, 03:22 PM
Stig Eliassen's Avatar
There are some plugins out there, like Altiverb, that has a "reverse" button. Duplicate the snare track, bus it to the reverb plugin, and nudge it earlier to taste.
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
FS: DW Craviotto maple snare, 14"x5.5", 2003, mint ctmartin Buy & Sell 0 08-13-2012 08:03 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
How do you get a "Haunted" or "ghostly" sound yijvapar Virtual Instruments 9 08-03-2009 07:04 PM
"Be There" snare drum sound MV Tips & Tricks 7 10-09-2002 05:28 AM
