Old 03-09-2001, 10:57 PM
michael c michael c is offline
Default Digital Calibration Level
We have our studio calibrated at -12 db. If the idea is to record as close as possible to digital '0' without going over, I was wondering if (in our case) -12 is too low. If our analog mic pres and compressors are hitting analog meters at 0 VU and higher with peaks, we are only hitting our PSX-100 at -12 digital which is way below '0'. What level is the optimum level?
I realize it depends on how much headroom your mixer has. But is it better when using the PT mixer to record basically at -12 on each track or to get as close as possible to digital 0 and bring the faders down as needed for the mix. This means we would need to calibrate our studio at a higher level. Thanks.
Mac Pro 3.5GHz 6-core (6.1 2015)
Sierra 10.12.6
64 GB RAM
1 TB PCIe flash storage
Pro Tools Ultimate HD 2019.12
HD Native Thunderbolt
Old 03-10-2001, 11:14 PM
BDWillis BDWillis is offline
Default Re: Digital Calibration Level
The AES standard for digital levels is -18 dB. However, your description sounds like your analog pre's & comps are operating at a nominal level of -10 dB (consumer level), as opposed to +4 dB (pro level). Digi's 888 i/o's have internal jumpers that allow them to be set up for -10 dB nominal level, but I don't know about the PSX-100. There are a couple of chapters in the TDM Hardware Installation Guide (re: calibration, nominal level, etc.) that might help you sort it all out.
On your second point — yes, record individual tracks at the highest possible level, and keep faders low during mixdown so as not to beat up PT's stereo bus. Then use Waves L1 (or Digi maxim, etc.) as master insert to bring the stereo bus level up, although I try not to do more than a 3 to 5 dB of stereo bus Maximizing… it starts to sound terribly smashed & unmusical, with less depth. Good luck.
Warmest Regards,
Brian
003 Calibration Level drummer9 Pro Tools 9 0 06-30-2011 05:38 AM
CALIBRATION LEVEL Sput 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-20-2006 07:36 AM
Level calibration DonaldR Tips & Tricks 1 11-02-2004 08:31 AM
listening level calibration? anders Post - Surround - Video 5 10-11-2002 04:09 PM
level calibration coaster Tips & Tricks 0 11-27-1999 08:57 AM
