#21
Re: Anyone else having the "can't access upper menu's" bug?
Not so sure my friend. Check up thread a bit, Ive been having this problem with VERY few plugs, all verified as compliant.
Best, Sean Sean McDonald Red Medicine Recording LLC Sofa King Music Services http://www.seanmcdonald.com |
#22
Personally, I use SuperDuper, as it does a better job of drive cloning. Of course, it's not free like CCC... |
#23
I'm really not sure what's up with your system. I can say with almost certainty that this issue is not Pro Tools - our investigation shows this happening with other applications. The best advice I can give is to start looking at other applications on your computer that may somehow have an effect on Pro Tools - utilities that run in the background, etc. Every case we've seen of this has been solved by plug-in updates, OS reinstalls, working from a new admin account or removal of extraneous software from the system. I know that's not much help, but it's all I can offer at the moment. I think this is one of those 'many causes, single symptom' issues that defy simple answers. |
#24
I'm still having the problem.
G5 Dual 2.0G, PT 7.4.cs7, Digi 64-bit chassis, HD Accel, Mac 10.4.11 I really don't think this is caused by anything other than ProTools or plugs. I have updated all my plugs to what they're supposed to be. Any other ideas? |
#25
#26
For the record, I have had this issue too. Running Waves 5.9.x did not help.
I recently updated to Waves Ver 6. Perhaps that will help. It is a PITA. Closing and then restarting Pro Tools seems to fix it for me, or at least until the next time whatever function trap is causing this occurs again.
Wyn Davis - Total Access Recording Studios Redondo Beach, California |
#27
I believe that it's a PT issue because this rig has been running for the last three years or so, with no problems. It is only used for music, so there are very few non-music apps (like none, really, other than Safari and Firefox). I haven't added any non-music apps for a long time (years). The only thing I *have* done is to update PT from 7.3 to 7.4, and concurrent with this general transition, this has cropped up. When it happens, I can click onto the Finder, and from there there upper menus are accessible, but the moment I get back into PT, the upper menus are not accessible. We have updated every plug in accordance with the compatibility grid. So, I'm a bit baffled. It only happens when we're in PT, and it's happening on a frequent basis, typically when we jump out of PT to access the internet or something like that. Then when we go back to PT, no upper menus can be accessed. So, I then have to Command-Q on my keyboard to quit all the way out...then relaunch PT. This process takes several minutes, as we do have a lot of plug-ins. The last plug I installed was the JJP Collection (Waves), and I recently removed that plug to see if the problem still came and yes, it did. Aside from that plug, I haven't installed any new plugs since before this started happening. But I have updated PT as each new CS release has come. |
#28
#29
Digi, yes, it's not rare that we would have a browser open at the same time that we have PT. But I've also noticed that if I simply click out of PT while it's still open, and then go searching for something on a hard drive, when I go back to PT, the menu's are no longer accessible. In other words, it typically doesn't just happen...it seems as though when I leave PT for any reason, when i go back I have the troubles.
Good suggestion about the PT prefs. When I get some time, I'll take out JJP, trash the prefs and try again. |
#30
Please check your Expose settings in System Preferences. Turn off all Active Screen Corners shortcuts (so the pull-down menus display "-"), and just to be safe all Expose and Dashboard shortcuts as well. Does that make a difference?
assertion in "..\Mdie_TrackPlayer.cpp", line 469 / access violation/ DAE error -9400 | thibault | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-22-2013 05:08 PM |
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 03:04 PM |
Help with Pro Tools "Access violation occurred unable to read dll" issue | dfeeley | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-16-2011 09:01 PM |
hardware buttons for "preview", "capture" and "punch" | evs | Post - Surround - Video | 1 | 12-06-2010 12:28 PM |
"access violation " protools can not make auto backup " | nachonieto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-16-2008 03:54 PM |
