How do I get rid of "Missing Files" message when PT loads?
Each time I load a particular session in Pro Tools M-Powered (7.3.1cs7), I get the following message: 2 Audio files, 0 Fade files, and 0 video files are missing..."
I have chosen to "Skip All" each time because I have all the audio files and fade files that I need in the session. However, this message keeps appearing each time I load this session. How do I keep this from happening? Thanks in advance for your help! |
Re: How do I get rid of "Missing Files" message when PT loads?
i ran into that before but don't remember exactly how i fixed it. it was either using the task manager or maybe doing a save session copy in. sorry.
Go into the regions list view(the 1 on the right of the edit window) Look thru the files until u see ones that are sorta italicized for lack of a better description... click on all of them(if its ur 1st time doin it u may wanna write down the missing files to make sure u dont grab the wrong things) anywayz, get all those files highlighted, go up to the dropdown menu in the same window, go to select, choose clear unused regions, & then when the popup ask to remove or delete, hold alt+click on delete & that'll do it...
MYSPACE ON'EIM LAUTEN MICS & ME DA'TUBE ON'EIM 'IS TAMARA HOME' NO, SHE'S WITH HOBO KEY '' (that dopey green thing) ('we' must start using pronouns) |
U may want to check again b/c there has to be if ur getting the missing files popup... ur in the Region window to the right on the mix window & not the 1 on the left correct?...
If you do end up deleting all unused regions as keybeeetssss has mentioned, (good idea... loosens up some memory) make sure you've unhidden any tracks that you may have Unactivated from the list on the left side of your session... Otherwise, you could end up deleting something you really didn't want to...
Thanks
Take care brush your hair, Rey https://r-e-y.com/ macOS Ventura Pro Tools 2022 iMac (Retina 5K. 27-Inch, 2020) Processor 3.6 GHz 10-Core Intel Core i9 3.6 GHz Dual-Intel Core i7 16GB ram AMD Radeon Pro 5700 8GB Shure SM7B Mic Pro Tools | Carbon Komplete Kontrol M32 AKAI Mpk3 Mini KALI Lp 6 (2) |
Pro Tools sudden "missing iLok" message when connected external USB devices. | mgoorevich | macOS | 5 | 01-04-2012 02:13 PM |
Getting regular "missing Ilok" message after upgrading to V9 | SD2 | macOS | 5 | 01-26-2011 12:46 PM |
PT 8.1 audio "hits" or "pops" when i open files from PT7... | djoeyd77 | Pro Tools TDM Systems (Mac) | 1 | 10-31-2009 03:59 AM |
"Missing Files" - Another Feature Request | Bignjhammer | Post - Surround - Video | 8 | 02-26-2009 01:17 PM |
Structure - what does "Monolithic" mean as it pertains to "part" files? | Jared_TL | Virtual Instruments | 2 | 12-07-2008 03:37 AM |
