You are running out of CPU with one RTAS on 8 cores?!
When running two mono tracks (one L and one R from a final mix output) and running T-racks deluxe 3.01 I am getting "You are running out of CPU power. Remove some RTAS or increase CPU usage limit in playback engine"
Ive got 16 cores allocated to RTAS playback and CPU usage to 90% . My system usage within PT LE "CPU (RTAS) was at 13% and my OSX activity monitor was less than 4 bars for each virtual core. I don't think I should be getting this error based on the system stats. Whats going on here? cheers -MTLA
2009 MacPro w/Two 2.26 Ghz Quad-Core Intel Xeon "Nehalem" processors - 6 GB - Mbox2 PRO - Pro Tools 8 w/Complete Production Toolkit - 3 x KRK RPG 6s, 2 x KRK RPG 5s, 1 x KRK 10S / T-racks 3 / Izotope RX / Wave Arts / PSP / Massey / Joemeeks / ARC system/ Snapper / Microphones galore |
Re: You are running out of CPU with one RTAS on 8 cores?!
Try taking out one of the cores. So make it 15. Some plug-ins require a core to do non real-time processing. This should help. If not, report back here.
Hope this helps. |
I was having the same problem with T-Racks 3 Deluxe. Someone here said that some RTAS plugins don't "know" how to work with two or more processors, as they're only a "converted version" of VST and not "real" RTAS. This worked for me: on Pro Tools, click Setup, then Playback Engine. Set RTAS Processors to 1 Processor and CPU Usage Limit to 99%. This prevented some of my VST-adapted plugins from giving me this "running out of CPU power" error. Regards |
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
if i make my ram from 2GB to 4GB will that make a difference?
Yes irfanshakeit
Yep. It did for me.
-------------------------------------------------- Why do people keep running over a string a dozen times with their vacuum cleaner, then reach down, pick it up, examine it, then put it down to give the vacuum one more chance? |
How many cores for RTAS in playback engine? | Logichead | Pro Tools TDM Systems (Mac) | 10 | 10-11-2011 06:25 AM |
64 Bit Pro Tools? RTAS Working on ALL Cores? | Bentley Ferrari | Pro Tools TDM Systems (Mac) | 45 | 03-31-2009 09:24 AM |
TDM On "Harpertown" Cores Running 10.5.1, What about 4-core? | SmokinBaldMonkey | Pro Tools TDM Systems (Mac) | 0 | 05-03-2008 11:06 PM |
anyone running tiger smoothly on new 8 cores? | alw4416 | Pro Tools TDM Systems (Mac) | 11 | 04-19-2008 07:26 PM |
Can't leave RTAS set to all 8 Cores?? | alw4416 | Pro Tools TDM Systems (Mac) | 12 | 04-11-2008 12:10 PM |
