Old 04-29-2014, 10:47 AM
Funkmasta69 Funkmasta69 is offline
Default Plug-in Automation Question
Hi guys I've been trying to find a solution for this and it's driving me nuts, it might be a very simple thing but I can't find the answer, I'm running PT10 CPTK
and I'm trying to copy the plug-in automation from one track to another, this is a moving automation, like a filter sweep, not just plug-in settings (cmd+shift+c/v) I've tried copying special and all sorts of things but I can't do it, I do not want to alt+drag that plug-in to that track because if I do this all the previous automation will be lost, any ideas???
Old 04-29-2014, 11:26 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Plug-in Automation Question
Paste special to current automation type should work fine? are you viewing the automation type on the receiving track when you paste?
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-29-2014, 02:58 PM
It worked when I selected the track that I wanted to automate and went Edit-Paste Special-Repeat to Fill Selection, I guess that'll do!
Thanks Chris!
Old 04-29-2014, 03:06 PM
The weird thing is that it'll only let me do it when I use the menu bar and select to copy "All automation" and then Paste to fill..., Plug-In Automation is greyed out and won't let me select it, the other weird thing is that when I try to do it using right click on selection it will allow me to copy Plug-In automation but it won't paste it, which seems really odd... Anyone experienced something similar?
Plug in Automation RTPro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-20-2012 09:39 PM
General Venue Automation Question - (Maybe dumb question) TwoPort VENUE Live Sound Systems 5 12-21-2007 02:41 PM
Plug-in automation question Bookerv12 Pro Tools TDM Systems (Mac) 2 01-28-2003 07:37 PM
Plug-in/automation wish talkingdog Pro Tools TDM Systems (Mac) 0 07-04-2002 11:51 AM
Automation plug-ins(Question for DIGI) maxserg Pro Tools TDM Systems (Mac) 1 04-12-2002 08:46 AM
