PT keeps saving files to system drive ARGGHHH
Hello all.....
Recently I looked at my system HD and noticed that multiple session's "audio files and fade files" where saved to my system HD. Although I have ALWAYS used an external firewire for all my sessions. I've noticed this happening quite often. Am I hitting something or doing something wrong???? I always end up having to copy the files over to my external. Then PT says "missing files" I show it where to locate the files and "commit" to the new links. kindof a hassle. Is this related? I noticed also on my system HD that there is a folder called "Volumes". Most people have this folder though its usually HIDDEN. For some reason or another, mine is visible. Anyways, all it is a is a folder with aliases to all internal and external hard drives. Anybody else have HD/Volumes folder visible??? Could be related? I dunno....... ....i thought maybe this folder was telling PT to save files onto different drives. thanks in advance for all your genius!!!! |
Re: PT keeps saving files to system drive ARGGHHH
Do you have round robin record allocation enabled?
Are you using template sessions stored on your desktop? Are you checking your disk allocation when you create your session to be sure things are going where you want them to? |
I don't really know about the round robin allocation. In my workspace...everything under "A" is listed R. Everything under "V" is listed "T". What is it supposed to be?? A, P, or T?? Does anybody have a visible "volumes" folder on the main HD??? on the first level directory. |
I don't think that folder has anything to do with your problem. You should look into the disk allocation options and answer the other questions I asked because this is most likely simple operator error. (99% of these problems are)
I don't know if that's related to this, but thought I'd relay that, in case it may be relevant. As for Shawn's questions - what he was asking that you answer was if you had round robin allocation enabled. Go to Setups>Disk Allocation and see if the box for Round Robin is checked or not. |
I'm not sure if its double mounting. I just see a folder named "Volumes" on my main HD. On every other computer in the house, its invisible. Inside it are aliases to my main HD (with a hard drive icon) and my external drives and partitions (square icons with globes in them). It may not be the same prob as yours?? I dunno..... To reply to shawn, I followed his directions. Round robin is not enabled, and my disk allocation is set to the right folder, under my pro tools FW drive. As for my workspace is concerned. I read somewhere that PT mays sometimes save audio files and fade files on different drives if they are labeled "R" under the workspace. Is that true. What should my workspace "A" and "V" be labeled? |
If you 'show full path names' in the Regions bin - where does it show these files are located?
I'm wondering if that Volumes folder may be part of the problem - it does sound suspiciously like the issue I had, which drove me nuts for weeks. |
Round Robin is actually a setting that is saved with the session, so it's possible that some sessions have it on and others don't which could make it difficult to catch unless you pay close attention. From your description it does sound like you have some sort of networking element working on those drives, but I still doubt that's part of the problem. You say it's "invisible" on the other machines, but how do you know it's simply not there at all? My suggestion would be that you start specifically visiting the disk allocation window to verify that you don't have any special allocation options set so that all of the tracks are routed to the proper root media folder and that you don't have round robin enabled. Do this on every session, everytime you open them and I'm betting your issue will disappear. |
Randomly Saving Files To The Wrong Drive (C) | rocknrollchef | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 04-29-2008 06:52 AM |
HELP! why is pro tools saving some files to my C:/ drive? | flail_19 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-20-2007 12:34 AM |
Fade Files on System drive ?????? | FSM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-10-2007 05:23 PM |
why is pts saving files on my system drive ? | unclemonkey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-19-2007 02:17 AM |
Is it ok to playback audio files from system drive? | Marzuki | General Discussion | 19 | 11-21-2001 12:24 AM |
