#41
Re: PT 2021.10 Bug Thread
You mentioned Piano V. Are you on V2? My config is pretty different from your on Mac, so it's possible that the stability gap is due to the plugin version (or the plugin altogether) or the Windows implementation, or your setup.
Kerry Smith http://apothekerry.com Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro |
#42
1. PLAY REC STOP NOT WORKING. 2. Cannot eject the M32 safely. Killing one of four NI-processes makes the M32 ejectable (is this a word?) 3. At startup PT sometimes reports that PT "PT cannot communicate with..." the M32. 4. Did not receive the 25$ voucher 5. No Sounds.com link/access Kinda messy. Tips are welcome. Support ticket on-going with NI. No solution yet. "Remove FB360 from plugin folder" It seems to me NI just emptied their garbage can on the market. Is NI a type of company that would do such a thing? /T |
#43
I'm on V collection 5. Have kept it up-to-date, but not upgraded. Piano V is in version 1.1.0.205. Means V1 I suppose. Can't find any compatibility info on V1, but it worked just fine on PT 2021.7. Yeah end then there is windows... ... /T |
#44
BUG? (maybe I miss something here...)
Inserting time before bar 1 (to make room for Intro): -Initial tempo marker in red, moves to the right same amount as time inserted. -Cannot be deleted or moved. Expected the initial tempo marker to be positioned at the beginning of the new bar 1 , i e to the far left in the edit pane. |
#45
You can't move it via Event operations? Tempo marker/Song Start won't move on its own due to insert time because that could screw up work you've already done and how it lines up to linear time. But you should be able to move it via Event Operations.
2021.6 and 2021.7 restart after exit | NJsound.com | Pro Tools | 12 | 08-11-2021 01:45 PM |
Downgrading from 2021.6 t0 2021.3 Mac M1 | Leon77 | Pro Tools | 2 | 07-21-2021 09:43 AM |
bus error in thread main thread at address 0xbfffd010 | abayman65 | Post - Surround - Video | 2 | 01-28-2010 07:17 AM |
Hey, where is todays..'Everyones sick of the XP issue,heres another thread' thread? | greenroom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 05-10-2002 11:59 AM |
