My Artist Mix (latest one) is connected via ethernet switch and was flakey...but what helped was to assign it a static IP in the AM settings and change Use DHCP to NO.
Overall, connecting seems to be more consistent but will still flake at times and need to go to EuControl settings and add it to My Surfaces. |
Tried that and also no luck. I also tried pro tools / eucontrol with and without rosetta and still have that problem. I also uninstalled all the plugins to see if something was causing this, but no luck. Still just have a 10lb paperweight on my desk.
This is extremely frustrating. Again, I'm using an artist mix with M1 Max Mac Studio with Monterey OS. |
![]() Quote:
https://duc.avid.com/showthread.php?...k16FfwHGVmi_Es
Stein Tore Sønsteli My private mixing room: Pro Tools Ultimate 2023.6 (HDX-2), Mac Studio M1 Max, MTRX Studio, Avid I/O's, S1 + Dock Main studio at work: Pro Tools Ultimate 2023.6 (HDX-1), Mac Studio M1, MTRX I/O's, Avid S6 24-fader. Audio editing suites at work: Pro Tools Ultimate 2023.6 (HDN), Mac Studio M1's, MTRX Studio, Artist Series control surfaces. |
![]() Quote:
![]() Quote:
I've pretty much got the same setup, slightly different mac and 2 more surfaces, latest PT and Eucon. Like you - the surfaces are detected and connect, but don't appear in PT even though PT acknowledges Eucon is running. |
I've seen Eucon successfully working on M1 Macs running Monterey 12.6.2, further about security changing these settings might help;
Check security and privacy in accessibility in your mac system settings, and make sure you have Eucon and ProTools ticked. The next thing to try is to reduce your system security settings, here's a link from the apple site > LINK I'd go for; Reduced security and Allow user management of kernel extensions from identified developers The new macs are shipped out by default with the highest level of security which could potentially stopping EuCon from working I'm not 100% but worth a go, you can always switch the setting back on if it doesn't fix it. Good Luck! |
EuCon is still functioning here w/ OS 12.6.2, though it does continue to lose my iPad Control app regularly (the app just closes on its own, so more likely a Control app issue than EuCon itself).
![]() Quote:
The app on my iPad just updated this morning to 2022.12.140
. System info https://duc.avid.com/member.php?u=57185 ![]() |
No solution as of now. I'm quite upset about this.
![]() Quote:
Mbox not supported by MacBook pro MacOS Monterey 12.x | Maripersen | Pro Tools 12 | 4 | 09-17-2022 09:24 AM |
Avid Quartet and macOS Monterey | gng75 | Pro Tools | Duet & Pro Tools | Quartet | 0 | 04-24-2022 05:41 PM |
macOS Monterey 12.3 officially supported! | DerrickC | Pro Tools | 62 | 04-01-2022 01:31 AM |
Mbox3 pro MacOs Monterey SIP suggested | Madsvigeholm | macOS | 5 | 12-28-2021 09:25 AM |
