Old 11-14-2002, 11:08 AM
Pako Pako is offline
Default PTLE 5.3.1 with higher sample rates that 48khz?
Question:
Lets assume that I have outboard, digital recording equipment that can save the files to hard disk at sample rates of 96-192khz. Will PTLE 5.3.1 handle that sample rate? I realise that my 001 is limited to 48khz, but is the software also limited? That rases another question, is it the hardware of the 001 that determines the max resolution for playback and editing or is it the software?
The reason for my question is this:
What if I had a session recorded on a HD or Radar24 system at much higher sample rates. Can I use those .wav files in the higher sample for mixing/editing on my PTLE system.
~Cheers~
|OS 10.2.8|80gb ATA100|120gb ATA100|
|Mac|FW800|DP 1.25ghz|1.5gb Ram|
|PTLE 6.1.2|Digi002r|Digimax|
|Recent PC to Mac convert|
Old 11-14-2002, 02:48 PM
Default Re: PTLE 5.3.1 with higher sample rates that 48khz?
Pretty dumb question, eh? (bump) [img]images/icons/wink.gif[/img]
Old 11-14-2002, 05:04 PM
CGlass CGlass is offline
Only if you have digi 002
Old 11-14-2002, 06:58 PM
So if you had a 002 session going on at 96khz and loaded the session on your buddies 001 system, it wouldn't work?
Performance disadvantages with higher sample and bit rates scott llamas Pro Tools 11 12 11-15-2013 06:15 PM
PT9 A&H ZED-R16, no playback at higher sample rates redbull Windows 10 09-20-2012 11:04 PM
ADAT, AES, higher sample rates Uli Rennert macOS 0 04-19-2011 09:23 AM
44.1 vs. higher sample rates Stacyodell Pro Tools TDM Systems (Mac) 88 09-22-2007 11:37 AM
any arguments against higher sample rates like 96? Tito Ricci Arballo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 01-08-2004 10:33 PM
