Old 11-29-2022, 05:45 PM
teedeecee teedeecee is offline
Default Comping Multitracks - Tips?
Hi folks,
I do a lot of multichannel orchestral pop and film work and have been using a source-destination 4point approach using playlists for years. Only recently I have started to look at using the comping feature but am a little stuck and wondered if anyone had some tips.
If I have say 5 takes of the same work recorded across 30 tracks, laid out over individual playlists then I change to "Playlist" track view mode I can then see all playlists. Selecting a time region then moving the selection to the target track it works as expected. However, if I move one of the children regions left or right in its playlist track, some of the members of the group will move the selected track to the target whilst others will not.
Is this a mode I am in or is there some approach of grouping etc that I am using that is borking this?
Old 11-30-2022, 07:13 AM
dcoffset dcoffset is offline
Default Re: Comping Multitracks - Tips?
If all the tracks are in a mix/edit group then playlist edits should work across all the tracks. I would check your group settings as a starting point.
Generally speaking I would never do edits in the playlists with the original takes. I would comp (copy) the segments to a new playlist and edit them in this new playlist. This makes it easy to go back and compare to different takes or recover work if you go too far...
Studio: Mac Pro | OSX Catalina | PT 2021.6 HDX | DAD AX32
Remote: Macbook Pro | OSX Catalina | PT 2021.6 Ultimate | UAD X8
Old 12-01-2022, 01:50 PM
I'm with dcoffset. Start by making sure all tracks you wish to comp as a set, are in an active group. Next, make sure that playlists are indeed being selected correctly(if not, you may need to disable the group and re-order playlists on some tracks). I also second his comment on adding a new playlist for the "comp" track(I usually name that "trackname.comp" or "trackname.final" without the quotes).
Further advice:
1-when auditioning playlists, hit STOP when changing which lane you are selecting(with the lane SOLLO button) because if you don't hit STOP, what you hear might be the last playlist, at least for a few seconds(IOW, switching is not always instant). Hitting STOP and PLAY means that what you hear IS what you expect to hear.
2-for future enhancement of the process, name your original track as "trackname.01"(without the quotes). Doing this will make each newly added playlist automatically named with the next number(so, trackname.02, trackname.03, etc). That way, you know that .01 is the first take, .02 is take 2, .03 is take 3. This helps a lot in any tracking, but helps a ton when doing multiple takes on multiple tracks
Old 12-01-2022, 11:07 PM
Thanks for your assistance. From your points I can see I am doing the right things. I will upload a video of the behaviour I am observing.
Old 12-09-2022, 01:07 PM
originalscottyg originalscottyg is online now
As an aside, I like to name the track without the suffix, then flip to a new playlist with the .01 suffix for the first take. This leaves the no-suffix playlist as my target comp playlist and the actual takes still match the playlist numbering. I just have to always remember to flip a playlist before recording the first take.
Scott Gatteño
Stems vs Multitracks Drew Mazurek General Discussion 83 06-25-2021 04:59 PM
Pro Tools 11 Tips and Tricks - "Comping Vocals" Kenny Gioia Tips & Tricks 11 09-29-2013 07:05 PM
Collecting Rare Multitracks? tha]-[acksaw General Discussion 10 12-30-2010 02:00 PM
zeppelin and motown multitracks?? travista00 Pro Tools TDM Systems (Mac) 2 09-25-2003 11:16 AM
