Old 03-06-2014, 01:48 AM
focusonsound focusonsound is offline
Default Avid Pitch II sounds damaged with automation
Hello,
yesterday we've tried to automate the ratio parameter of the new Avid Pitch II Plugin from 109% back to 100% and it sounds really damaged. Changing this value manually while playing sounds good.
Anyone else with this behaviour? Is this a bug?
Greetings from Germany,
focusonsound
www.focusonsound.de
Old 06-06-2014, 09:38 AM
maro maro is offline
Default Re: Avid Pitch II sounds damaged with automation
I experienced the same problem: after I automated the "Fine" parameter in Ptich II, it sounded very distorted/damaged.
It sounded good while I recorded the automation, the distortion ocurred during playback.
This seems to be a bug? Does anybody have a solution?
Old 06-06-2014, 01:32 PM
DetroitT's Avatar
DetroitT DetroitT is offline
As a side note for HDX the Native version sounds bad as described above. However the DSP version does sound clean.
So an update should bring this around for Native users.
(I thought this was a HDX only anomaly)
Old 06-06-2014, 05:21 PM
Dot Dot is offline
yup i can confirm that too
www.dominicdotokune.com
Old 01-29-2015, 05:40 AM
Fir3bird Fir3bird is offline
Experiencing the same problem. Seems like a global issue. Any updates on this?
Fir3bird
PT 10 & 11 / Octa-Capture
Vaio Z (Win7 64bits)
Full details on my profile...
Old 12-01-2022, 01:34 PM
kirsty kirsty is offline
I'm still having this problem. Looks like it never got fixed?
Old 12-01-2022, 01:53 PM
Is it making the automated change when no audio is present? With audio present, any pitch change would likely cause a glitch in the sound that I would expect. What are you trying to make happen? Maybe there is a better way to reach your goal
HTML code is On
Avid Virtual Instruments 10 installer, no XPand sounds? digidesigner Virtual Instruments 1 10-12-2012 01:21 PM
Pro Tools SE/Avid - add my own sounds/samples/instruments hamdemon Pro Tools SE and Essential (Win) 0 05-31-2011 11:36 AM
Audiosuite Pitch 'n' Time on an Avid? reichman Post - Surround - Video 1 01-06-2010 07:26 PM
