Old 11-27-2022, 08:34 AM
Blinkofani Blinkofani is offline
Default MIDI clip creation when moving volume fader
Well, I didn't think I'd say this one day but for working with external MIDI synths/modules, PT seems more suitable than Logic Pro!! Anyway, something I don't get(well there's a lot since I'm no PT guru!!) is the second I move the MIDI volume on a track in the I/O column in Edit View, PT creates a MIDI clip 1-bar long. Why is this? Is there a Pref I can click to not have PT do that?
Thanks for any cue.
M1 Air, macOS 12.6.1, PT 2022.10, Logic Pro X 10.7.5, UA TwinX, UAD2 Satellite Quad TB
Old 11-27-2022, 11:12 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: MIDI clip creation when moving volume fader
It may be that a clip has to be created for any automation that occurs outside of any existing clips on the track. I'm not sure if that's what is happening in your case, but I experience similar behavior when working with MIDI.
Help Us Help You
Chris
Focusrite Liquid Saffire 56
FocusritePro 40 (2)
TCE Studio Konnekt 48
Rascal Audio Tonebuss 24
Slate Digital VRS8
Gigabyte GA-Z170-HD3P
i7 6700K 4.1 GHz
32GB DDR4
macOS 10.15.7
UAD-2 Octo Core PCIe
Pro Tools Ultimate 2022.12
Old 11-27-2022, 12:14 PM
Thanks for the reply. That would make sense if I’m drawing automation as it has to be contained in a clip since it’s midi info and not mixer info but I only want to set the initial volume of the sound on the midi channel.
It may be that the midi settings on the track header are not sent to the external instrument so the info has to be placed on a midi clip to be sent to the outside world.
Now, if I record midi notes at the start of the session on a track, the clip with the midi notes will be «*on top*» of the volume clip. Does PT only send the data that is in the «*top*» clip or will both be sent, in such a situation? Thanks.
Old 11-27-2022, 12:37 PM
Hmmm, 18 years of midi(in Pro Tools) and I can't say I have ever grabbed midi volume. I just go to the VI plugin that midi is driving and adjust the plugin's volume Having said that, your needs may certainly be different than mine. Consider:
1-maybe adjusting the volume IS changing midi data(I don't know)
2-are you adjusting volume on an empty track?
3-what happens if you are in notes view? For me, the only time I use Clips view is when doing a copy/paste of midi data
Old 11-27-2022, 05:05 PM
Thanks for your rely. This site cancelled twice today my replies so I’ll make this second try short. You might be on to something about the fact there’s no midi clip already present. Maybe it will incorporate the volume info in any existant clip..
midi notes disappearing when moving to clip boundary santoorman Pro Tools 2018 9 08-14-2021 04:11 AM
Volume Fader versus Clip Game snowplaysmusic Getting Started 4 05-01-2020 08:31 PM
10.3 and 10.3.1 Small Volume Fader AND Clip Gain Fader Problem Ale macOS 1 10-11-2012 11:07 AM
Reason Rewire MIDI volume fader stuck grateful 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-25-2011 01:58 PM
Midi Fader Volume - Instrument & Midi Track blizzard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-11-2010 10:35 AM
