Old 04-21-2021, 03:38 PM
LDS LDS is offline
Default D-command/D-control with M1 macs?
Just wondering if anyone has given an M1 Mac a swirl with their d-command/d-control? I imagine it might work under Rosetta, but given the amount of work that perhaps needs to go into getting Pro Tools up and running natively on ARM chips, is this the end of the road for d-commands/d-controls with Mac?
littledevilstudios.com.au
Pro Tools Ultimate 2020.12. OSX 10.14.6. HDX1. DAD DX-32R. DADman 5.4.5.1. Mac Pro 2013. 10 Core 3.0gHz. 64Gb. Blackmagic Extreme HD. Sync HD. Dobly Production Suite 3.5.
Old 04-21-2021, 10:15 PM
ripekeai ripekeai is offline
Default Re: D-command/D-control with M1 macs?
I quickly tested with my M1 MacBook Air and it seemed to be just fine. Didn't do any heavy lifting but it connected and the faders + EQ section all worked.
Old 04-24-2021, 02:09 PM
arche3's Avatar
arche3 arche3 is online now
Great to hear!
Sent from my SM-G986U using Tapatalk
Old 04-25-2021, 04:18 AM
Led Led is offline
Why wouldn't it work...if it has an ethernet socket and the network driver to support it..the protocol is all handled by Pro Tools.
Andy Evans
Sound Designer/Composer/Mixer
Melbourne, Australia
www.mud.net.au
Old 04-25-2021, 07:57 AM
Still needs a working driver. There is also no technical reason why Pro Control or original DigiDesign Command24 would not work, but without drivers no chance. Good to hear ICONs are not left behind.
Old 04-26-2021, 08:37 PM
LDS LDS is offline
It's the added layers of complexity with M1 Macs that makes me wonder. Rosetta 2 seems to be doing a pretty good job of recompiling the current Intel version of Pro Tools for use on ARM processors. HDX and HDN hardware on the other hand doesn't work at all yet. Avid really need to do something, otherwise a lot of people may have half functioning pro tools systems.
The transition to a native M1 version of Pro Tools, combined with the release of the hybrid engine and recently mentioned 2048 voice count might be seen by Avid as an opportune time to ditch the old Digidesign ethernet protocol entirely from Pro Tools.
You know... progress (or keeping the proverbial Avid gravy train moving forward).
command 8 /control 24 or other control surface for HD 68topls Pro Tools TDM Systems (Mac) 0 12-26-2009 12:25 PM
Control 24 / command 8 or other control surfaces with HD 68topls ICON & C|24 0 12-21-2009 05:47 PM
Tactile control of PTLE without Command|8 Control|24? Blackshapes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-05-2009 09:39 PM
Using D-Control/D-Command to control Pyramix SoloMonk ICON & C|24 1 10-18-2007 10:38 PM
intel macs vs. slightly older macs Jperkins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-14-2007 09:36 AM
