Old 07-19-2023, 11:51 AM
EddieJones's Avatar
Default EUCON 2023.6 Avid Control released early. Download link for EuControl
The App Stores released early this time. Heres a download link for the Workstation software, until we get the release onto our servers/myAvid/download Center etc.
EUCON 2023.6 Mac
EUCON 2023.6 Win
Whats New in EuControl 2023.6
Old 07-19-2023, 07:50 PM
James Steele's Avatar
James Steele James Steele is offline
Default Re: EUCON 2023.6 Avid Control released early. Download link for EuControl
Hi Eddie... sent you a private message. May have found an issue with the new version.
M1 Max Mac Studio, 64GB/2TB, macOS 14.5, DP 11.32, Pro Tools 2024.3.1, MOTU 828es, MOTU 24Ai, MOTU MIDI Express XT, UAD-2 TB3 Satellite OCTO, Avid S3, Console 1
Old 07-20-2023, 05:28 AM
Hi Eddie,
the "select Eucon Application" drop down menu doesn't show up over here. I have KeyboardMaestro added under Application.
(I guess because it's not supported? but here the entire menu doesn't show up)
Does this new feature mean someone could add Streamdeck to EC to that we can use a Streamdeck instead of the iPad for EC without going through SoundFlow?
Thanks
Frank.
PTHDnPCIe 2024.6 (OSX13.6.7), 8x8x8, MacPro 14,8, Decklink SDI 4k, SYNC HD, Nanosyncs HD, 64GB RAM, Xilica Neutrino, Meyersound Acheron
Old 07-20-2023, 06:50 AM
This new version is super flakey for me. Constant disconnects and random freezes also on the S1 now. Is there a way to downgrade the FireHD10?
Often I can add the tablet but it won't react. EC says it's claimed by my PT. When I hit remove it gets removed but the tablet app doesn't react at all. When in finder I see zero hotkeys, as if EC has lost it's normal key assignments. Restore and revert on the softkey page are all greyed out.
Seems really buggy.
Old 07-20-2023, 07:23 AM
its2loud its2loud is offline
What troubleshooting steps have you done?
Completely uninstall the Eucon application and reinstall
Delete AC from the tablets and reinstall.
Try again.
You don’t add Keyboard Maestro to the application whitelist. The whitelist is for other application that you want Eucon to control when focused. For example, running Pro Tools and Logic at the same time and having Eucon control for both.
Streamdeck does not work with Eucon without Soundflow. The integration is tied.
Old 07-20-2023, 07:32 AM
Well that's not how it's described in the "what's new" pdf. It says you add the app that you want to potentially control and then it shows up the EC command window in that drop down menu. Thing is: the screen shot in the manual shows a drop down menu in the Eucon Command page. That menu doesn't show up in the EC app.
But that's just a side note. The whole EC setup has become completely unstable since the update. After install the app also show a splash screen with completely random text "salad" It says "welcome to avid" and below: "UBLF!LKJDKJCNJKJEHEJBNCNJÖLHNK:BJNSKJKJSNJNJDNJB! " afer tapping on the arrow another screen appears with random text gibberish and an OK check mark. Not a problem per se but the whole thing seems strange....
Old 07-20-2023, 08:02 AM
hugoleitao hugoleitao is offline
Panning dot on Control App not moving, but moving in Pro Tools..
Same with Dock knobs
Quit the app will fix it temporally but will happen again
Pro Tools Ultimate 2023.6
Mac OS Monterey 12.6.7
Old 07-20-2023, 08:11 AM
EddieJones's Avatar
Only EUCON Apps work in EUCON. Soundflow added EUCON not Keyboard Maestro
Old 07-20-2023, 08:12 AM
EddieJones's Avatar
First thing to try is to Uninstall EUCON and check the remove all prefs box, reboot and reinstall. If this doesnt work come back and we can troubleshoot more
Old 07-20-2023, 08:21 AM
Thanks Eddie
Did that before post it, it doesn't fix it
PT 2023.6 not appearing in Avid Link Bill0287 Pro Tools 1 06-08-2023 08:53 PM
Avid Link 2023.6 Now Available DigiTechSupt Technical Alerts 0 06-07-2023 10:45 AM
Avid Link Download Errors for Avid Link 2022.9 and Pro Tools 2022.9 cmhawke Pro Tools 11 03-08-2023 02:45 AM
any link to download eucon for mc mix? cant register anason-records Artist Series 8 08-28-2014 05:47 PM
