Old 04-22-2024, 04:45 AM
Redpony Redpony is offline
Default Re: 2024.3 Bugs to Confirm
It turns out the folder bug is not a bug and now it makes sense. The shortcut follows the edit cursor or edit selection. This emphasizes work being done on clips and needing a shortcut to manipulate your view since you have a distance to travel to click the folder button.
This info is in the manual, which I should have consulted first but I am now accustomed to Cubase's manual, which is terrible. The Pro Tools manual is a proper, good old fashioned manual. Been reading it and will finish and consult.
Old 04-23-2024, 06:44 PM
I've run into another issue which appears to be a bug.
When selecting Default Midi Thru to be "first selected Midi track" I hear crackling and distortion when I click in on midi clips, notes, and in the piano roll. When I select none or the instrument that I am editing it works fine.
This is a feature I was hoping would work since I'm finding it hard to arm a track just to preview it.
This occurs at all buffer sizes including 1024. I am on a Mac Studio Ultra with 64 gig of RAM, so it's not the machine.
Old 04-24-2024, 08:41 AM
marianna's Avatar
marianna marianna is offline
Hi Redpony....
I see you have a case started and an audio tech will reach out thru the case but... could you please indicate the OS you are on with the Mac exactly as that helps when they go to reproduce it.
Standing by for that info so I can add it to the case notes.
Marianna
Marianna Montague
Sr. Dir. CX and Community | Customer Advocate
[email protected]
cell +1 (813) 493-6800
AOL IM avidmarianna
Twitter Avidmarianna
We're Avid. Learn more at www.avid.com
Old 04-24-2024, 05:56 PM
Thanks Marianna. I am on MacOS 14.4.1.
Old 05-02-2024, 07:12 AM
Follow up summary: the folder tracks work as intended and was not a bug but a consequence of how Pro Tools operates with edit selection/track selection. The distortion when using midi input thru was resolved by deleting preferences. I've been gun shy about using this feature again so can't yet say if preference corruption is to be expected. The issue of Kontakt crashing when duplicating tracks has been confirmed as a bug.
The positive side to all of this is that it has compelled me to read the manual, which is very good, and learn how to use Pro Tools better.
GetTrackList command still returns an empty array here - Pro Tools 2024.3/SDK 2024.3 GRT Pro Tools Scripting SDK Toolkit 6 03-19-2024 01:11 PM
11.1.2 on Mountain Lion bugs bugs bugs. command+f, elastic audio, discoloration farmfresh Pro Tools 11 21 05-01-2014 07:21 PM
8.1 Can you confirm a bug? Wolfgang Eller Pro Tools TDM Systems (Mac) 15 09-21-2010 10:59 AM
Just to confirm mario ebrio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 02-20-2008 07:33 PM
Bugs in my box - no, REAL BUGS !!!!!!!!! Mixtrix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-25-2006 06:33 PM
