Old 09-14-2002, 07:01 PM
surchur surchur is offline
Default automating plugins
I'm still not getting it very well. If lets say I just want a huge reverb to hit on just one snare and then return to normal is that something that can pop it instantely and then pop out, or is it really somthing more like a audio suite that has to be planned to come in and out. another words it doesn't really happen in real time. Anyway I realize im not understanding it well can somone run me through the step by step process Thanks
Old 09-14-2002, 07:24 PM
ReniuR ReniuR is offline
Default Re: automating plugins
The way I would recommend doing it is making a bus send from the track in question, returning it on an aux input track with the reverb plug (set at 100% wet) on the aux track, and then automating the send mute. This will give you verb on exactly what you want without cutting the reverb trail short or changing the sound of the original track.
-ReniuR
www.disposableproductions.com
Old 09-15-2002, 04:53 AM
ajazzie ajazzie is offline
Either that or just add to one snare.
Just play with a test track, set up the automated parts to a plugin and hit auto touch on your fader.
Play the track and mess around with the parameters, play it back, watch things move and see the automation in the edit window.
Forget the instructions and rules, you will get the hang of this in notime at all.
AJ
A Gentleman is one who can play the bagpipes, yet chooses not to.
Old 09-16-2002, 04:17 AM
guitates guitates is offline
Hold Command(apple)/Option/Control and click on any Plugin item...You will see the pop up window giving you "automation" choises.
Then in edit window, expand view to "medium" and click on "waveform" and scroll to bottom of pop up and there is the automation for you to manipulate to your desired result.
When finished hold command/control and click on the track name to return edit view to waveform.
I Seek the Holy Light...
Isaiah 40:31
72 Strat with single 2-Blade pickup
PTLE 10.3 LE
2-SSL Alpha Channels - 1 SSL G-Compressor
Apogee Rosetta 200 - Z-Systems Opti-patch
Lexicon MPX-G2 Guitar Processor - .003r
Command 8 - Roland JV1000 + Triton Rack
FOCAL TWIN 3way speakers + JBL Q108MK11 Bottom
2-52 jax MilSpeck Patch Bays
2-22" Apple Cinema Display's
Allen & Heath 16ch Mixr
**Currently = 11-1-12
2 CD's Released-1-2003-2-2012 Worship ROCK
Automating Plugins chagmaier 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-22-2012 10:39 AM
Automating several plugins schlawingo Tips & Tricks 8 02-25-2010 01:06 PM
Automating Plugins bakerusc Tips & Tricks 4 10-24-2006 12:03 PM
Automating Plugins skippy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-01-2005 11:32 PM
automating plugins viaspiaggia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 08-31-2004 10:10 PM
