DRIVERS issue with FW 003 DIGIDESIGN
Dear community, since 2 days, my PT 12.4 (win) does not work properly with my FW003 hardware.
I guess there is a driver problem, because, I've been trying to install the last driver from AVID, but the FW003 is not recognised. In fact: 9.0.8 does not work (not recognised) 9.0.7 does not work (not recognised) but 9.0.6 works, well, the FW003 is detected properly in devices manager, but no automation, no menu avalaible in lcd, just 'sound'. I don't understand why those last drivers don"t work ... is my FW 003 firmware up to date ? I've tryed when the device detected, to update by placing the hadware in the firmware mode, but nothing at all appended ... 'host' stops flashing for 3 or 4 seconds, and nothing else. does someone knows what exactly version is needed ? Here is my hardware details from the LCD display: boot 56A8 b7.3.0.116 system 4FA8 v8.0.0.314 fader v8.0.0.314 hardware 00.32 please, feel free to help me ! that sucks ! Nicolas. win seven family premium 64bits SP1 i7 3.6 ghz 32 gb memory |
Re: DRIVERS issue with FW 003 DIGIDESIGN
Did it work with an earlier version of Pro Tools on this machine and OS? Assuming this is a new setup, what is the firewire controller brand? VIA chips will often not work. TI(Texas Instruments) is the recommended FW controller. Next thing to check is what driver you are using. On most windows machines, there are 3 "resident" drivers available. The "Legacy" driver(which Avid recommends,m but never worked for me), the TI Compliant driver(which DID work for me) and a third driver I don't remember.
Dear Dave,
well, the PT worked fine until yesterday. I'm not sure, but AVID send us with 'avid application manager' 2 different updates. I guess the problem came with one of them. AVID told me today the driver I'm using is the one for 'console' and the 2 others, are in fact for rack 003. So maybe my problem is solve at 50%, but anyway, I do not have automation anymore. Just the sound onto speakers and headphone, all faders are now static. What do you mean for Quote:
... my firewire card is OHCI Texas intrument in PCIe.
In case you're still reading Nick, 9.0.6 is the latest (and last) driver for the 003 console.
I'm also having (different) problems with PT v12.4 and the 003, you're not the only one. Hope you get it sorted out.
Is that a real poncho? I mean, is that a Mexican poncho? Or is that a Sears poncho? Hmmm...no fooling... FZ |
Windows 10, Pro Tools 12.5, Digidesign Digi 003 Console (Factory), Driver 9.0.6... Same issue here. The 003 works and connects but the Automation and Faders do not work. Has anyone figured out a driver or work around to make the faders work and follow the faders in Pro Tools, Is this an issue AVID plans on working on or is the 003 Legacy dead equipment.
Producer/Engineer/Musician RIAA Platinum Sales Award: Lisa Stansfield "Affection" Main: Model: Dell 5750 Precision Workstation OS: Windows 11 Pro 64bit CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz, Memory:64GB, 2X32GB,DDR4 2933Mhz Non-ECC OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSD Focusrite Scarlett 18i20 3rd Gen AVID Pro Tools 2023.12 JBL LSR4328P 8" JBL LSR310S 10 inch Powered Studio Subwoofer* Yamaha HS50M Studio Monitors Alesis Elevate 3 Studio Monitors M-Audio Axiom 61 Midi Controller |
Go into Device Manager and click on the firewire controller and select Update Driver. Then select Let me Choose from a list. You should have 3 options. Legacy, TI Compliant and a third I don't remember. Avid recommend the "Legacy" driver(and you should give it a try). For me, that driver did not work, but the TI Compliant driver worked dandy(Windows 7 x64, 003 console and Pro Tools versions LE 8.0.5, 9.x and 10.x).
(Avid) Digidesign 003 - Drivers v.11.0.0 Issue! | Marc5000 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-25-2013 06:30 PM |
Updating Digidesign drivers... help | yijvapar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 11-24-2009 08:42 AM |
Digidesign Audio drivers 7.3 | frdescamps | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-30-2007 04:31 PM |
Digidesign Drivers | focacciaman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-06-2002 10:39 PM |
Digidesign O/P drivers... again | iamstudios | General Discussion | 5 | 06-10-2000 10:36 PM |
