I'm having a bit of trouble autonmating.I'm using Pro tools 8 m-powered. Mac OS X 10.5.6
How do I automate certain parameters in the EQ plugin? I set the channel to write and thats about as far as I got. I can't find anything on the EQ plugin to select what I want to automate. It says "Auto" at the top of the plugin, but I can't click it or anything. Thanks for your help. |
There's several ways. If you hold down command+option+control and click any parameter on your plug-in, a window will come up that asks you if you want to enable that parameter for automation. click on enable and you're there. Then in your track window you can select that enabled parameter as your track view, like waveform, volume, send, etc.
Any idea the hot-keys to do this on Windows Protools LE?
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack | |
Automating volume | nunuk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 09-18-2009 08:18 PM |
Automating Midi | caulds989@mac.com | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-22-2009 05:48 PM |
Automating plug ins | remute | Virtual Instruments | 3 | 05-20-2008 12:08 PM |
Automating tune | Glenn75 | Pro Tools TDM Systems (Mac) | 1 | 04-11-2008 04:54 PM |
Automating effects | Peter Groom | Pro Tools TDM Systems (Mac) | 5 | 01-21-2007 09:33 PM |
