Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 02-10-2023, 01:04 PM
MarkH MarkH is offline
Default Re: Carbon Expanded - ADAT
Does anyone know if there’s a way to get Mark Corbin’s attention on this thread? Would love his input.
Old 02-13-2023, 10:20 PM
I reached out to Mark and he was receptive to the feedback about enabling Carbon Pre ADAT ports in an Expanded configuration. Max sample rate would be 96k due to some limitations. I don’t foresee an issue there and it would be a welcomed addition instead of the ports not being usable at all. It’s on the roadmap but not committed, which usually means it’s 6+ months out in my experience. I’d love to see this scoped and committed sooner than that.
Old 02-17-2023, 06:30 PM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
This is good news to me since I'm now considering the Carbon Pre.
What is more relaxing than Music?
Pro Tools Carbon for macOS 12.7.4
My HDX for Windows11.
Gigabyte Z490 Vision D - BIOS F21b
Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams
Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1)
Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity
Bricasti M7 (2)
Lexicon PCM96
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Old 02-24-2023, 02:13 AM
mickglossop mickglossop is offline
I recently upgraded my whole Pro Tools system from the old 192-based system to a new one based around Carbon & one Carbon Pre.
I re-designed my workflow and re-wired my studio in order to access the (anticipated) 48 channels of I/O.
Imagine my disappointment to discover that the ADAT interfaces on the Carbon Pre do not work within a Carbon Expanded system, which means that I have only 32 channels of I/O.
This limitation was never made apparent in any Avid promotions I saw.
As pointed out above, there's little point in including ADAT interfaces which do not function.
OK OK they work in standalone mode, but I would bet heavily that the vast majority of Carbon users around the world are Pro Tools users, wanting to take advantage of the DSP/low latency in the Carbon.
Please - Avid - make this happen. I would be happy even if the allegedly restricted AVB data flow meant that use of the Carbon Pre ADAT ports was restricted to 96 kHz (or even 48 kHz).
Old 02-24-2023, 07:12 AM
I'm in a similar situation. I purchased Carbon and one Pre with the intention of buying a second Pre to run a full Carbon Expanded system. I had to hold off on the my second Pre purchase to see what the roadmap looks like. I was not aware the ADAT port on the Pre units cannot be used in an Expanded system. I've reverted back to my Galaxy 64 with the Carbon interfaces sitting in the box. I love the sound of Carbon and it's an amazing high quality interface with fantastic Pro Tools integration. The constraint on I/O is holding me back. I'm hoping my email to Mark Corbin incentivizes the Avid team to allow the use of the additional ports. I think they would sell more units if this was the case.
  #16
Old 05-08-2023, 11:43 AM
patmaki patmaki is offline
Hi all, new to the forum. I bought PT's last year after using Logic for 13 years (w Apollo X). I love PT as a DAW, and decided to take the plunge and invest in Avid hardware to get a more seamless tracking experience. I have a Carbon and an HD I/O 16x16 on order. A rep at Sweetwater told me I could connect the HD I/O to the Carbon via ADAT AND the DSP from Carbon would work on the 16 HD I/O tracks during tracking/mixing. Can anyone here confirm if this is true?
  #17
Old 05-09-2023, 06:52 AM
dominicperry dominicperry is online now
I don't know what config you have ordered for the HD I/O but the photo on Thomann (https://www.thomann.de/gb/avid_hd_i_o_16x16_analog.htm) shows only one optical port in and one out. If that's S/PDIF, then it's only 2 channels. If it's ADAT, then it's only 8 channels at 44.1/48k.
So you won't be able to get 16 channels into the Carbon over ADAT, only 8.
And those 8 will be at 44.1/48, not at higher sample rates.
Does that answer the question??
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
  #18
Old 05-09-2023, 10:01 AM
Something doesn't seem right. Avid discontinued the HD I/O. For a Sweetwater rep to recommend this now and sell you the unit seems suspect. The HD I/O units are intended for HDX systems.
  #19
Old 05-09-2023, 11:35 AM
K Roche's Avatar
K Roche K Roche is offline
Yes I just checked the HD 16 info and it does only have 8 channels of ADAT not 16 (and as Dominic noted only @ 44.1 and 48 K ) So at a price of $5k it is not a very good choice.
Me depending on how many simultaneous channels of analog inputs I needed.
If 16 or less I would just get the Carbon Pre to go with the Carbon it's only $3k And in my opinion is better mic pre's and converters than the HD I/O
If you need more than 16 then you can add another Carbon Pre but it will be another $3k
OR you might consider something like the the MOTU 16A 32X32 (@ $1500) which will give you 16 channels of ADAT (but again only at 44.1 and 48 K) which may or may not matter ..
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2023.12.1 Sonoma 14.4
Enjoy the Journey
.... Kev...
  #20
Old 05-09-2023, 11:49 AM
BScout BScout is offline
Cancel your order and get a new sales rep. That is 100% not true. You can't use a HD I/O standalone. And there is no shared DSP between a Carbon and HD I/O. You need an HDX or HDN card to use the HD I/O.
This is 100% wrong and embarrassingly so for a dealer to say it. Also a massive waste of money.
Pro tools Carbon and ADAT Rob Hannon Pro Tools | Carbon 10 02-09-2023 12:18 PM
Can I use Carbon ADAT OUT with 8 Preamps Simultaneously langa101 Pro Tools | Carbon 4 01-22-2023 02:17 PM
use Carbon and Carbon Pre together as one interface in Logic/Cubase ? pm mastering studio Pro Tools | Carbon 0 12-22-2022 01:54 AM
Adat detection Problems With Carbon Mike_sound Pro Tools | Carbon 14 10-23-2021 06:28 PM
16 channels of ADAT i/o from an un-expanded 192 GKF Pro Tools TDM Systems (Mac) 4 03-22-2007 04:09 AM
