Re: Monitoring while recording with native plugins in HD
why pray tell? B/C as Nerd states that what the DSP chips are for........Unless you are trying to take advantage of the native mixer having a higher floating point than the TDM counterpart. (iirc)
An other reason is that some people also tracked in the studio then went into a mixing room freeing the tracking room for other people to do their tracking, while they mixed the albums in the mixing room. There are probably more reasons too, but these would be the more common, well beside people running out of voices due to mismanagement of Rtas/TDM placements. And apparently ninjawed by J>Daniels .. I should have refreshed before starting to post. |
Hahah - I would just add that the quote where you said
"the difference in the sound to the advantage of PT Native" We should maintain the nomenclature of the time which would have been PT-Le But by no means, your post was much more technically adept
Hehe never thought about this, but it does make sense to take out the LE after admitting that the Native summing and processing engine were superior to HD's summing and processing engine.
Like I said, if you actually do read everything I said, is that I started this practice when I had an HD2, which could not handle all I needed to. Plus, me adding a hundred RTAS plugins to a mix, has very little impact on my computers performance, well the typical ones I use that are very low CPU draining plugins. If you have so much experience, why not just give it a try, see for yourself. Don't trust me, just give it a try.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp |
#16
u honestly think i havent used rtas in HD? I was forced to when i first got my system because i hadnt upgraded my waves to TDM and i had HD1 originally. I shortly realized i was gonna need more cards and to uprgrade my plug ins. Yes my system does everything I need and more. I wouldnt mind another card but that would involve a chassis. On occasion I will have to use rtas because i use all my chips. its not uncommon for me to use 20 auto tunes in a song and those babies eat chips like no other.
#17
Taking for granted that Native sounds better than TDM is an opinion, not a fact. It has been debated ad nauseum and has never been agreed upon. Personally I don't buy it and I'm not alone in this conclusion. If you apply proper gain structure there should be no difference in sound.
As far as using Native plugins it is totally situation specific but the latency for tracking is pretty darn noticable no matter what plugin you are tracking through. I have an HD 6 system and still have to use Native plugins for some of my needs, mainly because so darn many of the new plugins are Native only these days, but I would never track through them. At a 256 buffer setting even Slate VMR, which has almost zero delay, has a very noticable latency when playing through it when combined with a TDM version of Trim. The whole idea of tracking through Native on a DSP system is not really that workable. |
#18
The fact that Avid joined everyone else in the 32bit float world when it unified the PT mixer with PT, PT Native, and HDX tells you even they knew it was better. Not much debate there.
#19
#20
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
Which to buy, PT Native vs HDX? - I Need Input Monitoring | rcd | Pro Tools HDX & HD Native Systems (Win) | 3 | 11-05-2014 08:59 AM |
Does HD native or native native disable plugins when monitoring inputs? | BasketCase | Pro Tools HDX & HD Native Systems (Mac) | 7 | 05-20-2013 08:48 AM |
HD Native CUE Mixes Plugins and Recording | Nathan W. | Pro Tools HDX & HD Native Systems (Mac) | 7 | 12-18-2012 02:38 PM |
Input only monitoring in PT9 Native | koo_koo_bonkers | Post - Surround - Video | 6 | 04-04-2011 08:02 PM |
What recording software besides PT uses Native style plugins? | peter parker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-03-2002 11:04 PM |
