Select/Split notes not working in PTLE7
I can't seem to get the Select/Split notes command in the midi operations window to work for selecting notes with same relative positions within all the bars. I'm trying to select out positions of hihat 16th notes and the numerical entries for the range (between 1/000 and 1/000) don't seem to respond accurately to the range values I type in. Is this a bug or is there a secret to get it to work. I've spent too many hours trying to get it right.
Any help is greatly appreciated. Michael |
Re: Select/Split notes not working in PTLE7
Hello again - anybody from digidesign have an answer?? I'm specifically trying to select/extract notes with the same position in all bars from a hihat track containing all notes of the same note number. The select position command only works with positions of 1/000, 1/480, 2/000, 2/480, 3/000, 3/480, 4/000 and 4/480 for the btwn range entries. It does not matter what the grid note value is set to either. It will not work with 1/240 or 1/720 which are the other two 16th notes of the beat in 4/4 even after quantizing the track to an absolute 16th note grid. I've tried everything I can imagine and it's still a no go. Can someone help me with this please, Digi??
I'm not a midi genius, but this may work; click on the note of the tiny "keyboard" at the left end of the midi/instrument track that corresponds to the hat(or whatever sound you wish to split). That will highlight every hihat note. Hit Ctrl-X to cut, arrow up/down(using the p and ; keys) to your destination midi/instrument track and hit Ctrl-v to paste(you might use the COPY function instead of CUT, until you see if this will work for you.
Now, what is the goal here? Maybe there is another option you haven't considered
Thanks albee1952, I may give it a try. The select/split notes command in the midi operations window is supposed to let you select all notes of a given position simultaneously in all bars of a track and split or cut them out so you can edit only those notes. You can select them by a volume range, a duration range or a postition range. It is the position range I can't get to work fully. Thanks for your reply!
Split midi notes? Workflow? | JonLance | Pro Tools 9 | 9 | 08-07-2011 09:41 PM |
MIDI Select/Split Notes - Assertion in PT8 | gonzolagonda | Pro Tools TDM Systems (Mac) | 3 | 08-18-2009 05:34 AM |
7.4 Crash on Select/Split Notes | paulmellors | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-21-2008 08:40 AM |
Midi - Split Notes in Pro Tools | bassbuddy | MIDI | 2 | 09-18-2006 04:46 PM |
I have alot of "low end pop" a split second before playing single higher notes on gtr | mikerica101996 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-18-2000 08:01 PM |
