Keeping Mix and Edit windows open
Hello,
When I have the Edit window open, and I want the Mix window open I click -> Window -> Mix If I click anywhere in the Edit window the the Mix window disapears until I bring it back up. How can I keep the Mix window visible as I switch between the 2? Thanks Mike |
Re: Keeping Mix and Edit windows open
Joking aside, you would have to size the windows appropriately for them to both stay on the screen. You can also toggle between them quickly using the ctrl + = (press the ctrl and = key at the same time)
Cakewalk had a feature called "auto-activate" but as soon as they beacme Sonar, they dumped it.
As long as there was a piece of a window peepeng oput from anywhere, you placed the mouse and "Voila!", the window became active. Maybe the dev-team could consider this?
Derrkins GuyBarTola ******************** PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!! |
I think Ctrl+= is better because you keep the windows maximized and just quickly toggle between the two.
Screen space is pretty precious in pro tools, I don't see why one would want either of the windows minimized in any way, just to click and activate. two best solutions are ctrl+= or to get dual monitors. Even with dual monitors, I sometimes stretch both windows and still toggle to see as much as possible.
Joe Fitz Producer / Engineer |
I agree, jfitz; ctrl+= is the easiest way, and once you get used to doing it, it gets to be second nature. Kind of like ctrl+s
keeping mixer view open | aldersyde | Pro Tools 10 | 9 | 09-11-2023 03:36 PM |
Opening a saved sesh does not open a mix or edit window! | scott llamas | Pro Tools 11 | 1 | 11-16-2013 05:07 AM |
Keeping the 96io SPDIF "open"?? | buckaroo | Pro Tools TDM Systems (Mac) | 2 | 10-08-2009 09:13 AM |
How do set a session to open in the EDIT window by default? | dcarlson247 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-05-2007 11:59 AM |
How to maintain both the edit and mix window open | surchur | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 04-16-2002 11:18 PM |
