Noob question about MBox 2, PT9 and Macbook Pro
This may be a noob question but would it be better to use pro tools with an MBox 2 or the internal soundcard? I ask because PT normally works fine using the internal soundcard but a friend is selling an MBox 2 for really cheap. Is it worth buying?
Re: Noob question about MBox 2, PT9 and Macbook Pro
You're in the wrong forum. But since I use all that hardware on a mobile system, I will tell you that the MBox 2 sounds a little better than the MBP analog output, and the MBox 2 will give you mic pre's, dedicated monitoring control, and I think even MIDI. Compare "really cheap" to one of the newer MBoxes, or the Apogee Duet series, both of which will sound even better and be supported longer.
The MBox 2 would probably not work 'better...' - you would simply have an interface with multiple inputs and outputs- if you need that...
Eddie Sullivan Long Island Mac Tech http://long-island-mac-tech.com [email protected] 631 786 3924 Freelance Mac/Pro Tools tech for hire. Metro New York Area. |
It depends on what you want to do with it. If you consider only mobile editing and no recording, I wouldn't bother with Mbox and use the internal soundcard. You don't have to take any other box and cables with you.
Tom
BcA. Tomas Vitha Sound Designer and Mixer 2010 Mac Pro 8-core Westmere, OS X 10.6.6, PT HD 9.0.3, Mbox 2 Pro, C|24 |
Mbox 1 noob question | AudioHeadJosh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-19-2009 04:53 PM |
help!!! mbox is not conecting to my macbook*noob* | V22 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-31-2007 10:23 AM |
Mbox 2 vs Mbox 2 Pro (noob question) | WeNeverSleep | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-17-2006 12:33 PM |
Additional inputs for Mbox (Noob Question) | ParaplegicWaffle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-20-2006 02:52 AM |
Noob Mbox Question | Pimphish | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 12-05-2003 01:29 PM |
