I recently purchased a Macbook Pro 2.16 ghz Core 2 duo (NOT the newest one). I have been running PTLE 7.0/002R on a PC. I just had my boot drive on the PC fail, so I want to start running PT on the MBP. I am a noob when it comes to Mac, so if you would please help me answer a few questions...
1-Will my MBP recognize the sata HD I've been using for PT sessions on my PC? I'm hoping I can just pop it in an external FW400 or FW800 enclosure, load PT on the MBP and be ready to go. 2-My MBP has 1 1gb ram stick, supports maximum of 3 gb. Will I get better performance by adding a 2gb stick, or another 1gb? I thought ram should always be matched. Comments? Experiences? I thought I read somewhere of putting 2x2gb stick in the MBP even though it only supports 3gb total. 3-This will also be my first experience using an external drive via firewire. The MBP has both FW400 and 800 inputs. I'm assuming I should plug the 002R into the FW400 and get an external HD that has FW800. Best choice? Or should I daisychain the HD and the 002R via FW400? I apologize if any of this has been gone over in the DUC already, but I'm under the gun and need help fast! Thanks in advance to any advice! |
forgot to mention the sata drive is NTFS format
Ok, I own the exactly same machine.
1: Your MBP should recognize the NTFS-Drive in a Firewire enclosure, but you will not be able to work with that, as Macs only can read NTFS, but not write to this format. So, the way to go is: backup your data from the NTFS drive, reformat it and copy the data back. 2: My MBP has also 1 GB right now, and works. For sure, more RAM is better. If you are concerned about matching the RAM, just add another 1 GB stick. 3: FW400 and FW800 should work. As I don't have a FW800 drive until now, I daisy-chain them and it works without problems.
MBPr 15" (Mid 2015) i7, PT12.4, Studio One 3, UA Apollo Quad Firewire |
ProTools Noob - MacBook Pro performance advice... | miezurecords | macOS | 8 | 08-08-2011 11:41 PM |
Noob question about MBox 2, PT9 and Macbook Pro | RuffinMedia | Post - Surround - Video | 3 | 04-08-2011 01:44 PM |
Noob 003 Mic Pre/DI switch question | abt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-27-2010 01:10 AM |
2 noob questions | Munkiefan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-20-2008 11:42 AM |
help!!! mbox is not conecting to my macbook*noob* | V22 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-31-2007 10:23 AM |
