Old 05-29-2021, 01:49 AM
blue-element blue-element is offline
Default fader-problem on artist mix
Hello,
I'm working with 3 fader artist mix controllers. On one controller I have a problem with 2 faders.
1. when I switch on the controller one fader does jumping very fast up and down and than he stops on the highest volume setting (12 )
2. the second fader does not react and is on at zero.
I have done the newest update !
Is it possible to get new faders ( where to buy in Europe ? ) and does it work ?
Is there someone who has experience with this problem and can give me a suggestion ?
Greets b.e.
Old 05-29-2021, 05:16 AM
its2loud its2loud is offline
Default Re: fader-problem on artist mix
If you’re handy with a soldering iron you can try this...
https://www.pro-tools-expert.com/pro...vid-artist-mix
Old 05-29-2021, 11:44 PM
Thanks a lot for your help !
Artist Mix - reverse fader order - not fader flip inasimplerhyme Artist Series 4 02-21-2020 02:31 PM
First Fader of Artist Mix is stuck to whatever Dock fader is mrtomcat Artist Series 10 08-23-2019 01:51 AM
I just replaced a fader on an Artist Mix. Peter Baird Artist Series 8 05-10-2019 11:34 PM
How do I clean a fader on the Artist Mix? djmichaelwenz Artist Series 0 07-19-2017 12:05 PM
Artist Slow Fader FIX francois_harel Artist Series 5 05-19-2014 11:36 AM
