Old 04-28-2006, 05:34 PM
presence known presence known is offline
Default Changing global rotary assignments?
How can I switch the rotarys to pan on the edit pack, and all of the fader packs at the same time? If I switch it now, it just changes the pack that I'm on. I've had this issue before, but I don't remember how to fix it.
Thanks in advance.
Old 04-29-2006, 03:01 AM
Soundtrack Soundtrack is offline
Default Re: Changing global rotary assignments?
Changing Global/Local mode.
Press and hold the Opt(Alt)All switch, than press the Flip switch. The scribble strips abovwe the channel encoders will display Local/Global mode.
Select Global mode.
Global Mode works across all Procontrol Main and Fader units
Locall Mode is working only on the unit that you are working on .
No Rotary (Leslie) Effect dvjduck 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-30-2012 05:04 PM
Rotary effect MLE Eleven Rack 1 07-25-2012 09:27 PM
Changing track input/output assignments corrupts session files, causing PT to crash. horribleheaven Pro Tools M-Powered (Win) 1 07-08-2010 12:47 PM
Command8 rotary resolution? StachO ProControl, Control|24, Command|8 10 01-05-2009 01:23 PM
Rotary knob Auto? iank ProControl, Control|24, Command|8 3 01-28-2004 10:10 AM
