Old 01-25-2014, 02:00 PM
Electric Peak Electric Peak is offline
Default HD TDM Accel Number of voices per card both PCIx & PCIe
Hello, Does anyone know where I can find a chart for the number of voices per card for HD TDM Accel both PCIx and PCIe? I have an SBS Expansion Chassis with PCIx HD Core, 2 Accel and 1 Process. I'd like to know how the number of voices compares to a PCIe HD Accel Core plus 1 Accel card.
I've done a number of searches and would just like to see the number of voices per each card.
Thanks, Fred
Old 01-25-2014, 02:12 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: HD TDM Accel Number of voices per card both PCIx & PCIe
Wow I think I remember seeing those comparison charts online before or definitely was with some of the older HD documentation
Hd7 or hd8
Daniel
Old 01-25-2014, 03:13 PM
Thanks, I'm using HD TDM 10.3.8.
Old 01-25-2014, 03:17 PM
YYR123's Avatar
No I think the documentation was included on the read-me's for HD7 or HD8
You should dig around the HD7 or 8 pages to try and find it - I used to have one but many moons ago
Daniel
Old 01-25-2014, 07:13 PM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Thanks, Fred
Can't seen to find the chart, but if I recall correctly:
With the original non-accel core and process cards @48khz or 44.1kHz, you could get 96 voices per card, with a maximum voice count of 128 (requires 2 cards minimum). Once you put in 2 cards, you can not exceed this voice count regardless of the number of cards installed. ( An HD7 will have the same voice count as and HD2 )
By using at least one accel card and one other card (core or process) you can get 192 voices total.
Voice count is cut in half when you run 96khz, and cut in half again if you run 192khz.
All PCI cores are non-accel
PCI cores are PCI-X form factor, but are all technically PCI. The extra bank of pins is not actually used.
The early PCI farm (process) cards are non-accel
The later PCI farm cards use accel chips and are clearly labeled as such.
All PCIe cores are Accel
All PCIe farms are Accel
In any case, you need at least 2 cards, (one of them will need to be accel) to get the full 192 voices. So to answer your question, switching to PCIe will not gain any voices over your current HD4 PCI setup.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 01-25-2014, 07:55 PM
YYR123's Avatar
I'm gonna look for this - when I get home - it's gotta be there somewhere -
I specifically remember checking the differences b/t the PCI's and the PCI-e's
Daniel
Old 01-25-2014, 09:42 PM
YYR123's Avatar
http://avid.force.com/pkb/articles/e...Guide/en357859
Halfway down the page
Daniel
Old 01-25-2014, 11:45 PM
JFreak's Avatar
JFreak JFreak is offline
If you're referring to the MIPS chart, (yes there are differences between PCIX/PCIe) it has nothing to do with Voices.
Janne
Old 01-25-2014, 11:48 PM
YYR123's Avatar
Yeah I figured that after posting - trying to find that sheet
Daniel
Old 01-25-2014, 11:50 PM
JFreak's Avatar
Here's one which compares max voices of different systems
Janne
FS: Digidesign HD Core Card and Accel Card - PCIX/PCI N1h1l1ty Buy & Sell 7 05-30-2015 11:35 AM
standard pcix core card with accel pcix pie55 Pro Tools TDM Systems (Win) 1 02-08-2012 04:33 PM
TDM PCIx Cards in Magma AND Native Card in PCIe Logichead Pro Tools TDM Systems (Mac) 4 01-20-2012 05:54 AM
HD1 PCIe vs HD2 Accel PCIx propower Pro Tools TDM Systems (Mac) 1 02-05-2010 03:20 PM
PT 8.0 PCIe Core and PCIx Accel Card? Falk Pro Tools TDM Systems (Win) 1 10-14-2009 02:09 PM
