Old 10-18-2021, 09:01 PM
Brightbelt's Avatar
Brightbelt Brightbelt is offline
Default Routing through Buss track kills the volume
Hello,
I'm running Pro Tools 2021.7.0 on an iMac Pro (2017) with an 18-core Intel Xeon, 2.3 Ghz and 256 GB of ram.
This project is rather large, with 54 tracks, including all audio tracks, buss tracks and all aux tracks, and midi tracks etc.
Simply put, when I route my electric guitars through a Buss track (Stereo aux track), the volume goes way down. The guitars were recorded through a Direct Input via a Great River PreAmp. AND, this happens when there's NOTHING on the buss track...no limiter, no EQ etc.
My engineer tried creating a second buss track named GtrBuss2 (the first was named GtrBuss). It helps a little but when I compare these results by switching the routing the main Stereo Out, the volume jumps way high.
I appreciate any help. I still have much to learn about routing....Thank You, Frank B.
Old 10-19-2021, 07:34 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Routing through Buss track kills the volume
Try putting the Bus Track in Input Only.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 10-19-2021, 07:59 AM
Brightbelt's Avatar
Thank you for responding. I'm not sure what you mean.... I tried setting buss tracks to 'No Output" with only the Input defined....
Of course that didn't help - it cut off the routing chain and my audio didn't play.
Anyways, I'm not sure I did what you meant to say...Thanks....
Old 10-19-2021, 08:57 AM
Are you routing to the bus via track outputs or track sends? You really should use track outputs or if you're using sends use a prefader send.It's possible that you may have phase issues and that's why you're seeing a drop in level. Obviously you need to have an output routing so you can hear audio.
Jack
QAPLA!
Old 10-19-2021, 09:17 AM
Brightbelt's Avatar
I do both. I route effects in busses using sends for individual tracks.
I route Busses via track output for grouping instruments and using single effects.
Could two different electric guitars (1 is a Gretsch - the 2nd a Rickenbacker)
have phase issues both being recorded by Direct Input?
Thanks for your responding....
Old 10-19-2021, 11:42 AM
It's possible due to the internal wiring of the guitars. Where are the returns for the sends going? If you're using unique effects for each guitar instead of using sends just insert them right on the track and that way you don't have to mess with sends/returns.
Jack
QAPLA!
Old 10-19-2021, 04:11 PM
The Weed's Avatar
No, you need an Output of course.
I'm talking about putting the Bus Track to "Input Only Monitoring". See page 531 of the Reference Guide.
SonoBus
Old 10-19-2021, 04:42 PM
cwsand's Avatar
cwsand cwsand is offline
Looks like he's using an Aux track, not an Audio track.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 10-19-2021, 04:53 PM
massivekerry's Avatar
massivekerry massivekerry is online now
This might be a long-shot, but nothing so far has made any sense with my experience in this kind of situation.
If the routing has some additional processing that's not immediately obvious (like a Volume Trim Automation at the head, a Trim plugin, also routed to a channel with a polarity-reverse...)
Maybe look for something like that. Make a new Aux Channel that you route those guitars to, and make sure that they are ONLY routed to that Aux, and the Aux is ONLY going to the Master.
Kerry Smith
http://apothekerry.com
Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro
12.8 loosing multiple buss routing on crash Goombot Pro Tools 12 2 01-18-2018 01:51 PM
When routing an aux buss to audio to record monitoring latency Tristos Pro Tools 12 2 10-21-2017 06:36 AM
Why does PT8.1 not recognize the buss routing amptbuddy Post - Surround - Video 2 05-27-2011 07:36 AM
Second Track Kills Response from IMIC VGoodfellow Digidesign Hardware & Software 1 01-25-2002 12:51 AM
Do I really need to use the Master fader during final mix down..It kills my volume Trash Man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-04-2000 11:17 AM
