Old 09-03-2021, 03:20 PM
JMichalski JMichalski is offline
Default Eleven Rack Reamp
I recorded DI tracks, and I have a signal going to my amp. I'm using an xlr output on the back of my amp sent into the mic input of the eleven rack, however, there is no signal. What makes this confusing, is if I don't change any setting and attach a mic to the xlr, I have signal. If I disconnect the signal going into the amp and plug my instrument in instead, the mic input picks up signal. I can not send a signal from protools to my amp and get signal from the mic input at the same time. Any help would be appreciated.
Old 09-03-2021, 04:49 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: Eleven Rack Reamp
More info please?
  1. So you are re-amping with a guitar amp (only using the Eleven Rack for I/O)?
  2. What are the I/O settings for your track(s) in Pro Tools?
  3. What Output are you using on the Eleven Rack to go to the guitar amp?
  4. What is the level of the guitar amp output? (These are typically line level - not mic - even though they often use XLR connectors.)
linkedin
Eleven Rack Reamp Problem - No Audio Chence Eleven Rack 6 05-26-2015 09:34 AM
Eleven Rack ReAmp HELP ! Becharax Eleven Rack 17 03-13-2015 11:32 AM
Can't ReAmp in Eleven Rack (output inactive) jlg75 Eleven Rack 4 02-07-2014 09:10 AM
eleven rack reamp question anth Eleven Rack 2 02-24-2012 08:17 AM
How to reamp with eleven rack???? TeamContra Eleven Rack 3 09-07-2011 05:22 PM
