Dialogue levels and clip gain advice.
I am new at protools, and this new feature in pt 10, clip gain change, is a bit confusing, I am working on a low budget independent movie, and audio has recorded directly down on canon 5d with many problems, my questions is, I want to put my dialogue all at -10 dbfs, if the movie will have a sort of budget it will go in hand of a mix studio otherwise I have to deliver the final product, so I am looking for an advice to a basic approach to it. first dialogue has been recorded very badly with many levels variations along the time line, and it is noisy also, an annoyng hiss is present long the whole work. I set up my PT10 project bussing the dialogue channel to an aux channel with inserts in to it for the WNS denoiser waves plug in, and an waves l3 LL multi maximizer also. Thanks for our answers
Re: Dialogue levels and clip gain advice.
Why?
Clip gain will not be an effective way to achieve that end.
[QUOTE=Chief Technician;2016140]Why?
isn't that the general task about dialogue level? - 12 dfs or -10 dbfs and having some headroom for scream etc? http://socialsounddesign.com/questio...stering-levels what is the use of clip gain line why should I go to manage the original dynamic and not the volume that is the output post fader post eq and post inserts. |
I read in your original post that this is an independent movie. If that is true, then the text at the URL you linked to does not suggest normalizing to -12dBFS to -10dBFS. The article suggests the value of your dialog sit between -16dBFS Leq(A) and -12dBFS (LeqA). Normalizing, which you mentioned in your original post, is not the same as achieving consistent loudness. Normalizing will ensure that all of your peaks do not exceed the specified dBFS value if your source material is already over that dBFS value. Normalizing will ensure that any source material whose maximum dBFS peak is below your specified dBFS value will be brought up to your target dBFS value. The use of the clip gain line is to make a pre-fader adjustment to the level of the clip that you want applied at all times. The level that you set with the clip gain line follows the clip anywhere in the session. Quote:
If you really want to normalize, you should use the AudioSuite plug-in and have it create a duplicate file. This way you have the original file as provided and the normalized file whose maximum peaks match your specified dBFS value.
Adjusting Clip Gain On More Than One Clip | Blank Frank | macOS | 17 | 05-15-2015 06:34 PM |
AudioSuite Gain/Normalize also on Clip Gain | A-n-d-i | macOS | 0 | 03-13-2014 12:46 PM |
Export Clip With Clip Gain | BobbyDazzler | Pro Tools 10 | 0 | 03-03-2013 03:06 PM |
Clip gain on clip groups: bug or feature? | idris | Post - Surround - Video | 6 | 01-02-2013 10:48 PM |
Dialogue Levels | Zdenek Sychrava | Post - Surround - Video | 4 | 11-11-2007 09:47 PM |
