Revibe - outputs low end noise
hi, I was tracing an issue of having not enough head-room, and noticed that revibe (by itself) outputs about 15-20db of low-end (10-50hz) noise when using certain patches. can somebody please look into this ? cheers charles |
Re: Revibe - outputs low end noise
Can you give an example patch? Is it a factory preset? (Not that it should matter, but so I can test & verify......)
I have experienced this noises too. But you can more or less only measure it. I have a second computer using Elemental Audio Analyser and there I can see it. It does not have to do with different patches. I also found it on Ampfarm. I did not investigate further, since it appeared in some sessions and there was no certain way to reproduce in a new session. (I had it with larger sessions in the final mix.) best Hanz Marathon
www.marathon-music.com |
Revibe making noise? | Brandonx1 | Post - Surround - Video | 4 | 04-28-2009 09:07 PM |
Mbox 2 noise on outputs | coolcat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-24-2006 09:03 AM |
Noise from outputs | FingerFlicker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 02-03-2006 03:18 AM |
882 noise at all outputs | dbmusic | Pro Tools TDM Systems (Mac) | 3 | 04-17-2003 06:25 AM |
Noise on outputs | Jeremy Cook | Digidesign Hardware & Software | 3 | 05-14-1999 09:46 AM |
