RTAS Virtual Instrument Pop & Click Problem
After upgrading to PT 6.9.3cs3, I am having what sounds like word clock clicks in the aux channel return of an RTAS virtual instrument plug in. However, word clock is not the issue - I confirmed that all settings are correct. The plug in in question is IK Multimedia's Sample Tank 2XL. FWIW, I do not experience this issue with any other plug in (including other IK products). If you have any suggestions, please post them - it would be much appreciated. A search of this site (and IK's) yielded nothing specific to this problem.
Mac Pro 2013 2.7GHz 12 Core 128GB • Mac OS 10.5.5 • PT Ultimate 2020.5.0 • PT HDX3 • 192 IO x 8 • D-Control 32 Fader • UAD2 Octo Ultimate |
Re: RTAS Virtual Instrument Pop & Click Problem
What you are describing usually relates to CPU overload. What you can try , is increasing the buffer size ( ugh !), or..most virtual instruments allow you to control the active voices ( ie up to 16 or whatever). Try limiting active voice to something more reasonable - like 6, and see if that fixes you problem.
G5 Dual 1.8 /1.5 Gb Ram OSX 10.4.7 PT LE 7.3 cs1 DIGI 002 Waves Ren Sony Bundle Soundtoys-arama NI Komplete 3 |
Yep, sadly, increase your HD buffer from 128 to 256.
Thanks guys - increased the buffer size and, like you said, the problem disappeared. I'm not certain if the is a voice option on the plug in I mentioned.
That said, I am curious if there is a prescribed optimum settings FAQ anywhere around (haven't seen one). I know that there would be different settings for different tasks, but a rough idea for a balanced system would be helpful.
weird virtual instrument problem | aldersyde | Pro Tools 10 | 2 | 11-15-2013 09:10 AM |
virtual instrument input problem | thruhiker | Windows | 1 | 02-02-2013 07:42 PM |
help! abysmal RTAS/virtual instrument performance on my MBP | SamuelLJackson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-08-2008 11:07 PM |
Virtual Instrument problem | nunuk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-09-2007 10:28 AM |
virtual instrument midi track problem | acappellajosh | MIDI | 3 | 04-12-2006 09:53 AM |
