Old 04-12-2021, 09:03 AM
Danny_79 Danny_79 is offline
Default Some clean multichannel eq plugin?
I'm looking for a "clean" eq plugin(one that doesn't colour the sound sort of), that can process left and right channel separately and also process both summed together. Preferably aax plugin. The goal is to compensate for my rooms acoustics. I would want to have it on the master to remove it before bounce. I have a mesurement microphone and all...anyone know of any good plugin for this? Due to some technical reasons, i can't use sonarworks reference 4. Reason is, my speakers arn't far away enough from each other. And reference 4 demands them to be at a certain distance to do the process. My desk isn't big enough, and if i bought a bigger desk, i would have to remove my TV, cause my room is a bit small. With all this in mind, i know i can't get a flat listening environment, but i wanna get as close as possible.
Thanx in advance!
Old 04-12-2021, 10:42 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Some clean multichannel eq plugin?
Thanx in advance!
You could go with the waves graphic...
https://www.waves.com/plugins/geq-gr...0aAl1NEALw_wcB
There's no subtittute for good acoustic treatment! do as much of that as possible before doing room EQ.
Most cheap reference mics are not very accurite you have to pay top money for a good one. This approach will do nothing for you're RT60 reflections and stereo image will still be compromised. plus you're messing with the natural sound of your monitors, so be careful how far you go.
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-12-2021, 11:20 AM
Ben Jenssen's Avatar
Sounds like you're in a very small room. Big rooms or small rooms, they both have resonance, both small rooms are worse I think, because in a big room you can sit close and kinda separate the direct from the room sound. In a small room it's a mess. That's my experience.
I'd never expect a "room correction" solution to work ever, but I'm old.
Old 04-12-2021, 03:47 PM
BScout BScout is offline
FabFilter Q in min phase.
I wouldn't go graphic eq but parametric for sure. However, sounds like you are going to have a really lackluster result due to distance. But, hey, better than nothing if things are bad.
Don't get carried away with too high Q values due to the phase shift and after 1k or so do only broad shelf eqs (it gets pretty pointless due to wavelength and head movement).
But FF Q is also useful for mixing so the plugin will be useful elsewhere.
Old 04-13-2021, 10:15 AM
Originally Posted by crizdee View Post
Chris
Thanx! I'll have a look. I've done some room treatment but it's all foam, curtains, duvets, matrasses and so on....so it's probably not enough. The room is very dry, but i don't know about the lowest frequencies. There are 2 door openings without doors, so maybe they escape out of the room. Don't know. Anyway, my microphone is sonarworks XREF 20 mic, you know if that one's accurate? Not sure what RT60 means(?)
Old 04-13-2021, 10:18 AM
It's quite small but that's not all of it. It's also how the room is built. I could move some things around and have it work but it would mean some other practical problems, like getting rid of some stuffs, perhaps blocking doorways a bit, etc.
Old 04-13-2021, 10:21 AM
My suggestion for non-coloring EQ would be Sonnox EQ
Old 04-13-2021, 10:22 AM
Cheers man! Every tip is useful here. I'm sitting very close to the monitors cause of the distance. I do get quite a good stereo image tho.
Old 04-18-2021, 10:58 PM
matchmix matchmix is offline
Fab Filter or Sonnox for that
Old 04-19-2021, 02:06 PM
Weighing in:
I would NOT use a graphic EQ unless its all digital and specifically does NOT emulate an analog graphic. The reason being that analog graphics introduce lots of phase shift for every slider that is not set to -0(it might be possible for a plugin to be done with linear phase, but I am not aware of one).
Fabfilter in its linear phase mode should be a good choice(do remember to bypass it whenever you bounce out a mix).
For any EQ to work well in this application, you need some way to do accurate measurement. SMAART Live or Spectrafoo, along with a decent measurement mic would do the job pretty well(user experience/skill making a big difference).
The lowly EQ III 7 band can do a decent job(the measurement process probably makes more difference than the brand of parametric EQ).
Speaking from my own experience, system tuning CAN make a serious improvement if done right(of course, badly done and all bets are off). My first commercial room was small(at 12'x14') and even with lots of trapping and wall panels(all Owens Corning 703), I had a huge null at the mix chair at 50Hz(on the couch behind me was close to perfect). Adding a sub made a very modest improvement, but adding a digital EQ on the way to the sub, and tuning it with SMAART Live, I was able to get the mix position nearly perfect. Keep in mind that this tuning is going to help in 1 spot in the room, and NOT the entire room. If I had a producer on the couch, the sub stayed off so he got the "good" seat
HTML code is On
Eleven Lite plugin clean only. IGUNNZI AAX Plug-ins 7 02-28-2023 05:49 AM
Why do I hear both, guitar sim plugin and clean above it? sricabla macOS 5 06-24-2020 12:44 PM
(FS) PlugIn Folder clean up mpeg5 Buy & Sell 1 02-23-2013 06:51 AM
AudioSuite Plugin Multichannel preview HELP! bluesaint 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-18-2009 01:56 PM
favorite "clean" EQ plugin Will Russell Tips & Tricks 41 04-21-2002 03:04 PM
