Old 10-15-2021, 03:07 AM
Crank Crank is offline
Default Folders re-opening: unwanted behaviour
Hi and help please.
This has been going on for a while and I haven't been able to find a solution.
When using folder tracks I can close a folder from the console but often my session gets in a state where a previously opened folder automatically opens without me touching anything. This happens every time I open any other folder.
It happens with or without Automatic Spill of Attentioned Folder. It also happens when I close a folder from ProTools. It happens whether or not the folder that is automatically re-opening is attentioned or selected. Closing folders with the Transport Module Soft Keys doesn't stop the behaviour.
I have noticed that while this behaviour is happening the M10 shows "Please wait.. Loading Session Data..." every time I close a folder. Then the other folder opens again (on the surface and in ProTools).
The session will work as expected for a while then this behaviour starts and I can't stop it. It happens in every session using folders, small or big.
Re-starting ProTools doesn't fix it. Power cycling the M10 doesn't fix it either.
Has anyone else experienced this?
Any help will be greatly appreciated.
Lee
Old 10-15-2021, 04:31 AM
creativecontrol's Avatar
Default Re: Folders re-opening: unwanted behaviour
Greetings,
It sounds like you may be running EUCON 2021.6. 2021.6.1 addressed a bug where the session data on the desk was loaded erroneously:
https://resources.avid.com/SupportFi...leaseNotes.pdf
Also - I would recommend enabling (if you don't already have it on) the option ticked under Settings > User > Synchronize Folder State With Spill enabled,
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 10-15-2021, 07:47 PM
Thank you Jeff,
I've updated the S6 but now it's asking for Software License Activation. My ExpertPlus Plan is up to date but I can't find where to download the license file.
I've started a case but maybe you can help sooner than Avid.
Old 10-15-2021, 07:59 PM
Apologies Jeff,
I got it happening. Didn't follow the onscreen instructions to-the-letter.
Thanks
Import Audo Windows: Folders not opening Sonoman Pro Tools 2020 2 04-14-2021 06:35 AM
S1/EuControl - Unwanted Edit Window Behaviour JingleDjango Avid S1, S3, Dock and Control App 3 06-26-2020 10:34 AM
Unwanted behaviour-Most recently clicked stefanboman Avid S4/S6 10 08-27-2019 03:55 PM
Setting Mac Options when opening folders dubaifox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-29-2007 07:27 AM
UNWANTED +5dB on DX BUS!!! laudisi Pro Tools TDM Systems (Mac) 8 01-24-2005 07:02 AM
