Changing Hardware Setting to Clock ADAT using 002 LE
I seem to not have very many options when I open my Setup Hardware window using a 002 with LE. I do not see anything about the clock? I have looked in the manual and it looks very different than what I see. Please help.
Re: Changing Hardware Setting to Clock ADAT
"Clock Source" is on the left of the Hardware Setup window, choose the "Optical" option to clock to incoming ADAT signal.
Re: Changing Hardware Setting to Clock ADAT using 002 LE
It is not there in my software?
With Pro Tools LE, inside of the Setup -> Hardware window, there is only one parameter that has to do with the clock: Clock Source, which is on the left hand side like Slim Shady said. You should be able to choose between "Internal," "S/PDIF (RCA)," or "Optical" within the provided drop down menu. Perhaps go back into the reference manual and scroll to the beginning of the section that was describing what parameters you came to expect to exist within this particular window. It may be that it was describing the window as it would appear within Pro Tools HD, and is the case if it states (Pro Tools HD Only) underneath the section heading. Pro Tools HD has many more parameters in this window than Pro Tools LE. If that is not the case, I really don't know what it could be.
compressor setting volume changing | bryced87 | macOS | 6 | 04-28-2013 11:30 AM |
Command 8 goes offline when changing PT9 buffer setting | ajcler | Windows | 3 | 08-10-2012 03:24 AM |
Changing clock source freezes PT10 HD | imacgreg | macOS | 0 | 01-20-2012 12:10 PM |
PT 8.0.4 is re-setting my clock source.... | JayStyles | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 10-23-2010 06:54 AM |
"adat" option not showing in clock source: hardware setup! | Pran | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-02-2007 03:35 PM |
