Old 10-30-2021, 08:35 AM
ViciousLullabyz ViciousLullabyz is offline
Default Conversion from 24.000 to 23.976
I've just recently seen a BTS video of the production for Dune (2021) with the cameras shooting at 24.000 frames. The Web version (HBO Max) that is now available shows up on my receiver as 23.976.
It seems (after a bit of googling) that this is quite common and indeed most of my Blu-rays are also in 23.976.
As far as I can see the DCPs are kept at 24.000 and then the conversion is made for Streaming/Home releases, is that correct?
If so, where is the conversion made and how?
Is the film just played back 0.1% slower (resulting in it being slightly longer)? And is the audio time stretched by 0.1% and then kept at 48kHz or do we get a weird kHz number as well? Does the pitching usually happen after the final mix and is just made from the stems with Serato PnT or similar?
And regarding current big productions: How is this done in Atmos? Can the Dolby conversion tool do that or is there rerendering going on? (Maybe from the cinematic mix in the RMU to the 7.1.4 or similar HT version/renderer?)
Any (also partial) inputs are appreciated, thanks :)
Old 10-31-2021, 04:51 AM
Cheesehead Cheesehead is offline
Default Re: Conversion from 24.000 to 23.976
Personally I don't bother with pitch change with 23.976 deliverables from 24fps as the difference is so small.
I think its better than adding artifacts with pitch changing plugins.
24 to 25 is a different ballgame.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
Old 11-02-2021, 05:41 PM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
Correct. Both versions contain the same amount of frames but one plays slower than the other.
I use an app called Time Factory 2 that does both speed and pitch adjustments with very little amount of artefacts.
Deliverables for a film of that caliber will include common frame rates as default.
Vedat
WaveRider + Defaulter (now with LKFS)
QuietArt.co.nz
Catchin' SYNC app
HTML code is On
AES/EBU Conversion weso33 Post - Surround - Video 2 09-01-2009 07:28 PM
AC3 conversion cinetj Post - Surround - Video 4 06-04-2008 10:24 AM
AMR conversion edwardo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 04-17-2006 01:08 PM
what are you using for a/d d/a conversion? maskedman72 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-30-2005 02:44 PM
MP3 Conversion ? bassmac Tips & Tricks 4 07-27-2002 10:30 AM
