Spectrasonic problem in Pro Tools 8
When i try to load omnisphere or stylus rmx, session fall down without any comment! I don,t have this problem in previos vershion
Re: Spectrasonic problem in Pro Tools 8
We need more information? what version are you using? what computer and OS version etc. What do you mean exactly by fall down? a quit? whats happening? Chris
Omnispere hangs when changing certain presets. I have to close the plug-in and re-open it. I can see some sort of update coming in the near future.
Mac OS X ver.10.5.6
Proc. 2x2.8 Quad-Core Intel Xeon Mem. 6gb 800 MHz DDR2 FB-DIMM |
I have analogous problem with Omnisphere and Stylus RMX plus Celemony Melodyne Plug-in!!!
Mac OSX 10.5.6, PT8, HD Accel 3, PPC 2*2.3 G5, 6Gb |
In the hardware setup do you have the RTAS processor set to an odd number? This make a big difference for me when using Omnisphere. I got that advise from the Spectrasonics tech support person. In fact here is his email:
"Regarding the issues with ProTools, try these tips; 1. In Setup/Playback Engine set your processors to an odd number (if you have four cores, change it to three) 2. Keep your buffer above 512 (or to 1024) 3. Set your CPU limit to 99% Try those and see if that makes any difference in how Omnisphere behaves." |
I try Your recommendations but steel have a problem! What else can i do?
Make sure you go through all the troubleshooting steps and tips up above.
Trash preferences, repair disk permissions, lower processor count etc. Also I don't think 10.5.6 is approved by digi yet (although many claim to be using it without issues).
I have a different system to you: PPC Dual 2.7, OS 10.5.5 HD Accel 2 All Spectrasonics Instruments (including Trilogy) work very well for me. I never keep Omnisphere active when I'm done with the track. I always deactivate. It's a bit of a CPU hog. RMX though is working wonderfully well and uses very little CPU. I only have one processor activated. I had many problems when I had both selected. |
i reinstall 10.5.5 this night but it steel not working! All plugs ok but spectrasonics! Wonder why it work before i upgrade to 10.5.6
Atmosphere crashing PT 7.0..........spectrasonic | natural | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-10-2006 06:16 AM |
Spectrasonic Atmosphere,Stylus,and NI Kontakt too | moonmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-15-2004 04:39 AM |
Spectrasonic plugs crashing Accel on a G5 | kirkgale | Pro Tools TDM Systems (Mac) | 8 | 01-29-2004 07:08 AM |
How many Spectrasonic plugins can I expect? | chilisexnbeer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-17-2003 04:02 AM |
STYLUS SPECTRASONIC | Gabriel Caraballo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 07-31-2002 12:31 AM |
