Old 01-06-2016, 11:34 PM
guitarfreak846 guitarfreak846 is offline
Default "MOVE UNAUTHORIZED PLUGINS: Pro Tools could not load the following plugins..."
My bandmate just randomly started getting the:
"MOVE UNAUTHORIZED PLUG-INS
Pro tools could not load the following plug-ins either because no valid authorization could be found, the ilok key was not connected or the plug-in was damaged:"
I attached a screenshot below of some of the plugs acting up. All are stock PT plugs, like the AIR effects. So strange. It was working fine for a long time until now. His third party plugs work fine, though.
We trashed prefs, and even completely uninstalled then reinstalled PT10. No luck.
Anyone have any ideas?
File Type: jpg Screen Shot 2016-01-07 at 2.27.39 AM.jpg (36.1 KB, 0 views)
Old 01-07-2016, 09:10 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: "MOVE UNAUTHORIZED PLUGINS: Pro Tools could not load the following plugins..."
Welcome to the community.
What specific version of Pro Tools 10, and what are the plug-in versions?
linkedin
Old 01-07-2016, 11:22 PM
Thanks!
The most recent is what we have:
PT 10.3.10
Avid Virtual Instruments 10.3
Old 01-07-2016, 11:39 PM
crizdee's Avatar
crizdee crizdee is offline
Try installing the latest ilok licence manager.
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-07-2016, 11:56 PM
Tried that first. No luck.
Old 01-08-2016, 09:07 AM
jeffro's Avatar
PT 10.3.10
Thank you.
Can you check the specific version # of the actual plug-ins, like AIRChorus.dpm? Get Info or Properties.
Might help to trash specific prefs or repair permissions (if on Mac). What OS are you running?
linkedin
Old 01-08-2016, 12:10 PM
Originally Posted by jeffro View Post
Thank you.
1.0.2.10105 Copyright 2009 Digidesign, A Division of Avid Technology, Inc.
He's on El Capitan. We know it's not officially supported, but it was working fine for a while until one day this all happened.
Trashed prefs and repaired permissions... no change.
Old 01-08-2016, 03:05 PM
Ok, I've isolated it down to figuring out that ALL RTAS plugs, including 3rd-party, are having this issue.
Old 01-08-2016, 07:19 PM
jeffro's Avatar
If he's still getting the error after synchronizing the iLok in iLok License Manager then we should get his account info to review that. Will PM you for his info.
linkedin
Old 03-29-2016, 03:38 PM
askiles askiles is offline
Has anyone else figured this out?? It's not working for me either, all the same problems. Thanks!!
PT 9.0.2 "loud pop and No Sound" problem related to plugins and 002R bortraws macOS 18 08-17-2015 03:21 AM
"this action can cause loss of plugins in Pro Tools" after renaming a drive Terry Wetzel Pro Tools 9 4 05-01-2015 02:47 PM
Removed waves plugins, now getting prompt saying "locate" folder remusjacobs macOS 1 07-25-2012 06:15 PM
Pro Tools 9 "Quits Unexpectedly" on start, when loading Plugins! dbC4G macOS 6 04-06-2012 05:51 AM
Message "Pro tools with tdm requires the tdm mixer plug-in in the plugins folder" Alexei Zaitsev Pro Tools TDM Systems (Win) 0 01-10-2009 03:48 AM
