backward compatibility of sessions
Hello, I'm running PTLE 5.3.2 on a Digi002. My friend has some sessions on an external firewire drive recorded on PTLE 6.4. Can I open these sessions? Thought I'd better ask the experts first in case it would cause any problems.
Thanks. |
Re: backward compatibility of sessions
From the PTLE 6 compatibility documents:
Session Interchange — Pro Tools 6 & Earlier Versions http://www.digidesign.com/compato/xp/session.cfm Also, if you are the original owner of the Digi 002 and you purchased from an authorized Digidesign dealer, the update to Pro Tools LE 6.4 is free.
Administrator Avid Pro Audio Community |
It says "If you wish to move a session created in Pro Tools 6 to a system using an earlier version of Pro Tools, you may first need to select "Save Session Copy In..." to copy all of your audio files to supported sample rates"
Does the session need to be "Saved As" by the 6.4 user before I can open it, I presume? Thanks! |
This is also the best way to xfer everything between the two systems in a single session folder... good luck,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
PT Backward Compatibility?? | Mr. Kelly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-26-2010 11:06 AM |
Backward Compatibility with PT8 to PT7 | ecovindaloo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 06-06-2009 09:06 AM |
PT 7.4 backward compatibility | Tom Stoeckel | Pro Tools M-Powered (Mac) | 3 | 11-20-2007 11:32 PM |
Any word on forward/backward compatibility for PT5.1 sessions? | Burton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-08-2002 11:46 AM |
Backward compatibility of HD | ^Tripper^ | Pro Tools TDM Systems (Mac) | 0 | 03-13-2002 07:59 PM |
