Old 01-15-2004, 05:28 PM
shipwrecked shipwrecked is offline
Default 002 ASIO Driver Problem
Hi y'all
Have just started using protools recently and have come across a driver issue.The protools side of things are going fine, its just when i go to use cd architect or sound forge. Basically i cant get an output thru the 002.In Preferences the only device drivers showing are 'windows classic wave driver' and 'microsoft sound mapper' neither of which works.In Acid however, also made by sonicfoundry, everything is cool because the digi asio driver is available in the prefs for output. Is this something to do with non-installation of the wdm driver? I bought the pc (Carillon AC1) already setup with the 002 and am not sure what was installed and what wasnt.....can anyone help please?
Old 01-15-2004, 05:36 PM
Default Re: 002 ASIO Driver Problem
Download MME Helper from the WaveDriver download section of this site.. and add those apps to the Opt-in list.
You should also check in Start->Settings->Control Panel->Add or Remove Programs if the WaveDriver is listed. If it isn't then install it before using MME Helper.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Asio driver problem !? minniPT Windows 18 12-10-2012 08:47 PM
DIGI ASIO DRIVER PROBLEM WITH FL 8 "Not Enough ASIO output channels available. scottthafoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 04-19-2010 01:45 PM
PRO TOOLS 7 ASIO DRIVER PROBLEM instro001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-17-2005 07:57 AM
ASIO / Wav Driver Problem (or maybe not) jboaze 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-28-2004 10:44 PM
ASIO Driver Install Problem splattstudio Pro Tools TDM Systems (Win) 9 11-05-2003 12:05 AM
