Controlling monitor level from keyboard
Merry New Year!
Just got Carbon (coming from Apogee TB Ensemble). So the monitor level can't be controlled from the iMac keyboard with the volume keys??? Will this be possible soon - or must I resort to a monitor controller? Recommendations? I've read that some (like the Mackie Big Knob) color the sound. |
Re: Controlling monitor level from keyboard
You are correct, monitor level cannot be controlled from anywhere other than the control on the front of the Carbon.
There was some talk about monitor level being software controllable, but it hasn't happened yet. Pre-amps, yes, that was a firmware update, but not output levels yet. Anything you stick between the Carbon outputs and your monitoring chain is likely to degrade the signal unless you spend a lot of money. Is there a reason you can't use the front panel physical control? The alternative is to take a digital out from the Carbon (ADAT or SPDIF) and put an external DAC/monitor controller on that - I do this, using an RME ADI-2 Pro fs, but only because I already owned the RME and I like the sound of it. Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.4, Pro Tools 2023.12.1, Carbon. |
Thanks for the insight, Dominic - especially regarding taking ADAT from Carbon. I will definitely try that.
The Carbon is rack-mounted and it would be impracticable to constantly be reaching over for the front panel volume knob as often as I need to. I checked the RME... yea, at nearly $1k, a bit more serious than I was thinking. (I was looking at the TC Electronic Level Pilot X Desktop Speaker Volume Controller with XLR - $69. ) But, tonight while setting up an alternate workflow for the short term (until I get Carbon under my belt), it suddenly dawned on me that I'm in a similar situation as you were. I have an Audient iD14 that I can feed monitor output into. And guess what? It has a big beautiful monitor control knob. I've got Beatles running thru it now from the iMac - and it sounds good. By George, I think this solves it! Would you think that feeding it ADAT from Carbon is preferable to using the line outs? |
You would also need to be sure that both the Carbon was set to S/PDIF out and the iD14 to S/PDIF in. It's a bit of a faff, but I do have a Carbon and an RME Babyface connected to my computer at the same time, so it's doable if you have enough ports. It would be better to use the optical in of the Audient, rather than the analogue in - whichever way you do it you will be using the Audient ADC to monitor, but going digital from Carbon directly to iD14 will avoid an unnecessary round of ADC - DAC - ADC Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.4, Pro Tools 2023.12.1, Carbon. Last edited by dominicperry; 01-02-2023 at 07:35 AM. |
Glad you found a solution. Other options include using a tablet with the Avid Control app or a dedicated monitor controller. The Audient Nero has a lot to offer, gets great reviews and can be had for a very fair price ($333) from thomann music(cheaper than USA pricing even after adding the shipping). If you go that route, you might as well buy a Harley Benton guitar or bass for the studio(shipping charges get easier to swallow if you get more stuff)
I was lucky enough to have a Carbon on test in my studio for a few weeks. Indeed the lack of control of the outputs via the Apple keyboard or via Eucon is quite annoying. On my side I did some tests with several monitoring controllers and I had excellent results with the SPL MTC Mk2 and the SPL MC16. The SPLs improve things quite a bit and correct the main default of the Carbon, which is the high impedance of the outputs. The stereo image and low frequency are definitely better with the SPL between the Carbon and the monitors. |
I wish they just released a tabletop module connected to the AVB port to control, Volume,mute,mono and add a talkback mic for good measure (because the built in one is pretty much useless)
DOMINIC:
Geez - the whole reason I bought Carbon is because of its integration with Pro Tools... thought I'd be ridding myself of the intermediate software layer that I had to occasionally deal with when using the Apogee Thunderbolt Ensemble. So far, I'm not seeing a lot of upside to leaving the setup I had. Also was looking forward to the DSP advantage - but failed to realize I would need DSP plug-ins ($$$) to take advantage of that. My toolbox is all native plugs. DIGIOT: I'm with you. When I got the Avid S1, my first disappointment was realizing there was no built-in transport controls. Yes, soft keys took care of that, but still... MEGALOBASS: I'll check out the SPL. Thanks for the tip. ALBEE1952: LOL! Buy more stuff - save on shipping. Sounds like my wife's justification for shopping at Kohl's. "Look honey! I SAVED $800." I did look at the Nero, but couldn't swallow the $500+ price tag. I'll have to check out Thomann. Don't know much about the Harley Benton gear. I'm just trying to find some TIME to play the 1959-modded Strat and Mustang bass - hanging on the wall for 3 months now. (sigh) |
Dominic
And as far as only mixing in native, I do a lot of overdubs and punch-ins after starting mixes so you still need DSP-Plugins. Something to think about when starting to use plug-ins to mix. |
Controlling Send Level of a Battery 3 Cell? | ianbee | Pro Tools 10 | 2 | 03-04-2013 03:10 PM |
MBox 2 Pro not controlling level/volume of speaker? | daniel.yengle | General Discussion | 6 | 01-12-2011 11:24 AM |
Controlling things via my keyboard | Che_Guitarra | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-18-2008 04:00 PM |
Controlling Overall Level to Speakers in a Quad/Surround System | tcrist | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-17-2002 01:24 PM |
Controlling Keyboard With 001 | Styles Bitchly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-19-2002 03:12 PM |
