2020.3 is mostly snappy, but has anyone else noticed laggy beach balls when you drop a marker, select ALL groups and copy paste, etc? Is my template just too large? Just under 1300 tracks...
That's large. What are your system specs? You don't give any; might be underpowered.
With a session as large as that, it is good to try setting automation off for all tracks (with the option key) and only enable on the tracks where you need it.
![]() Quote:
Sorry, this hasn’t happened with previous updates. I have a MP 6,1 12-core 128GB RAM so nothing weak although not top of line. I have about 1000 of the tracks deactivated as I have a composition template and a audio post mix template “all in one.” So the whole compose folder stays deactivated when I am working on audio post. |
Catalina, Mojave, High Sierra...?
![]() Quote:
What vi's do you have loaded in your composition template? Still not full specs - you could put them on your profile page. All ssd's? |
I have done the optimzations. No VIs. All SSDs. It used to be snappy.
Please see it in action here. There is a black circle around my cursor when I click. Please play close attention to when I click. Before all groups are enabled my session is very snappy and fast. After I enable all groups (as you see in the video at :22 seconds), the session becomes very laggy. The reaction time after I click and when Pro Tools registers becomes very slow. Anyone notice same thing or have a solution? PT 2020.5, but was also happening on 2020.3. |
Ever since Sierra I have had to ask this question more and more often: have you clean installed your OS or upgraded?
My OS shown in the attachment 10.14.6 and I haven't clean installed in over a decade. This issue happens on my work and home computers which are not a clone of each other, but both on 10.14.6. I can send you the .ptx if you'd like to take a look.
spinning beach ball | monet | Pro Tools 2018 | 2 | 05-07-2019 12:43 AM |
Lag and Beach Ball | Intransit | Pro Tools 12 | 1 | 03-15-2016 03:58 AM |
Another Beach Ball - Crossfades | iluvatar | Pro Tools 12 | 3 | 04-09-2015 02:23 PM |
PT Beach Ball, Crash | keny | Pro Tools TDM Systems (Mac) | 2 | 07-24-2009 04:52 PM |
spinning beach ball when doing almost anything... | Muzoid | Pro Tools TDM Systems (Mac) | 4 | 01-01-2006 08:57 AM |
