Old 02-01-2023, 07:56 PM
ReynaldoPena ReynaldoPena is offline
Default Plug-in Doctor Alternative For Pro Tools
Is there an alternative to Plug-in Doctor for Pro Tools? For some reason the demo I downloaded is asking for the file up at the top of the plug-in interface (as it does not detect anything) and when I add the plugins for it to detect (dragging it from the pro tools plug-in folder), it says that it does not recognize the file.
Take care brush your hair,
Rey
https://r-e-y.com/
macOS Ventura
Pro Tools 2022
iMac (Retina 5K. 27-Inch, 2020)
Processor 3.6 GHz 10-Core Intel Core i9
3.6 GHz Dual-Intel Core i7
16GB ram
AMD Radeon Pro 5700 8GB
Shure SM7B Mic
Pro Tools | Carbon
Komplete Kontrol S49
AKAI Mpk3 Mini
KALI Lp 6 (2)
Old 02-01-2023, 08:56 PM
unkJE's Avatar
unkJE unkJE is offline
Default Re: Plug-in Doctor Alternative For Pro Tools
DDMF’s Plug-in Doctor is only for VST, AU, VST3
For AAX:
Bertom Audio - EQ Curve Analyzer
https://bertomaudio.com/eq-curve-analyzer.html
- see above link for compatibility
“EQ Curve Analyzer is an analyzer and signal generator plugin to see the frequency response (magnitude and phase) of any plugin or hardware.
Insert the plugin you want to analyse between two instances of EQ Curve Analyzer, the first one set as a signal generator and the second one as an analyzer. Then adjust the latency if needed. That's it!
It is particularly useful as a learning tool to see what classic EQs emulations are doing for example. It also features a "group" system that enables to compare two analyses in real-time on the same graph.
This plug-in is provided under the Pay-What-You-Want system, including for free. Please consider paying for it.”
Bertom EQ Curve Analyzer - Frequency & Phase response of any plug-in or hardware [update]
https://youtu.be/3Nl_Gi1IYfE
Pro Tools Ultimate 2022.12
Old 02-02-2023, 08:43 AM
Hey, thanks for the prompt response. Good morning. How are you? Hope all is well. Check this out. Im I doing something wrong?
Have a good day
https://drive.google.com/file/d/1K1L...usp=share_link
For AAX:
Rey
https://r-e-y.com/
macOS Ventura
Pro Tools 2022
16GB ram
Shure SM7B Mic
Pro Tools | Carbon
AKAI Mpk3 Mini
KALI Lp 6 (2)
Old 02-02-2023, 07:39 PM
unkJE's Avatar
Originally Posted by ReynaldoPena View Post
BERTOM – EQ CURVE ANALYZER popup Message:
“UNEXPECTED BYPASS
Your DAW is preventing this plugin to work properly by suspending plugins processing.
It probably thinks there is nothing happening on this track currently.
As a workaround, please enable input monitoring on this track, or put a dummy tone generator in your chain … or anything else that would force your DAW to run plugins processing on this track.”
What workaround did you try and what was the outcome?
Old 02-09-2023, 10:42 AM
Plugin Doctor itself has been available for AAX since last year. See here: https://ddmf.eu/plugindoctor/
What it doesn't do is support aax format for analysis even when Plugin Doctor is on an insert in PT. Only supports the aforementioned vst/au/vst3 formats.
Pro Tools 12 Renewal alternative VRW Licensing & Accounts 0 05-26-2017 08:00 AM
Suggestions for a Pro Tools Alternative. Terry Wetzel General Discussion 20 07-29-2015 08:27 AM
Pro Tools 10 Native a good alternative? MaxPayne Windows 3 11-25-2012 04:21 PM
Alternative to Pro Tools please? robertnorris 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 20 01-21-2007 09:35 AM
MS plug-in alternative? Frank Kruse Post - Surround - Video 10 07-16-2005 08:08 AM
