Need new update advice 8.0.3 cs1
Now i am whith WIN7 /64 bits PT8.0.3 and the (8.0.4b driver)allready installed. with a 003 working fine, my question what to do whith the
8.0.3 CS1 new update, if install it what could happend whith the current Digidesign Audio drivers x64 should reinstall this last againMaybe someone did allready My system is working fine i don't want ruin it thanks for any advice.
Jascha Koneffke flutist www.prodmusica.cl GA-X58A-UD3R[/ I7 950 RAM 24Gb corsair 1600 (3 sticks) 9-9-9-24 MAC MacBookPro i7 2,3 15" RAM 16gb PT 11.3 003 Rack MBox 3 Pro |
Re: Need new update advice 8.0.3 cs1
If it ain't broke.....don't fix it.
wise man has the power
But just in case someone do it, please tell us, good to know too.
As I said in response to your other post, I wouldn't do it
Is saver, as you say
Wait is the word
Yep.
And I see you are using a T.I. card. That helped me a lot with this setup.
yes the righter card than card before (via) via worked perfect till XP in Win 7 I had to change was loosing connection to my 003
Hi Jascha-
Could you give a brief rundown on what your order of installation was to get you to your current working setup? I'm about to install PT8 on a Win7 64 bit system. Thanks- |
I'll probably move this (W7-64) to the production computer soon. It hasn't given me any issues for a few days now, other than a few minor plug-in anomalies.
I did whith 8.0.3 full installer around 4GB click the set up with my 003 plugged but power off,then was asked to connect and power on the 003, i did it and continue till the end and restart, no warnings or errors. Then I power off my digi and install the 8.0.4b 64 bits, starting this installing I was asked to uninstall digidesign audio driver from 8.0.3 from control panel/uninstall programs, so did it and run again the 8.0.4b setup , I did and finish restarting (all this whith 003 0ff plugged but off) So I power off my PC, then power on 003 and PC next, went to device manager ,confirmed 003 appears there and confirm too about Port IEEE card TI driver. Never was asked to plug or turn on 003 while install 8.0.4b so think does not matter really,If you get a BSOD opening PT or not launch normal try a different drive for the 003,in Start /Devices and printers go to 003, look to update driver searching your self in your PC from a list, should be more than one or two see wich works better, that´s all really hope helps. One more thing maybe you could install 8.0.3 cs1 update after 8.0.3, then 8.0.4b in the same way course
Advice: looking to update system | Serip | General Discussion | 3 | 11-17-2011 10:58 AM |
Advice for update to system...? | Clarke | Pro Tools TDM Systems (Mac) | 3 | 03-10-2011 05:33 AM |
Need advice on update | Vashta Nerada | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 02-28-2011 06:56 AM |
seeking advice on update, 6.4 to 7.? | guy.fi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-01-2008 01:58 PM |
2 Questions Sampletank 2.1 update / advice on EQ.. | ProperTonez | General Discussion | 0 | 11-19-2006 04:29 AM |
