Why o why do you change the pro tools shortcuts?
Hi everyone,
I've upgraded recently my Protools 12 to 2022.4. I've not tested all the features yet, but I was really surprised that the keyboard shortcuts that I was using since Pro tools 8 was changed like muting a clip with ctrl+m. Why Avid?! Couldn't you just add that feature to change the shortcuts and keep the shortcuts we memorised since a long time by default and do not force us to take this extra time to remap them how are used to? It would be nice also to have the visual "saving" feedback that we had when we hit ctrl+S in the lower left side of the editing window. Thanks you |
Re: Why o why do you change the pro tools shortcuts?
I am running the very latest here and Ctrl-M works fine. Maybe your keyboard is the issue(I once had a stuck Ctrl key and it messed up everything). I'm sure that any changes would only be done after tons of requests. In any case, you are now free to change shortcuts as you like(at least in 2022.6).
Thanks for your answer. It was definitely not an issue with my keyboard. When i looked in the keyboard shortcut menu it was ctrl+comma that was muting the clip, even undo was changed to ctrl+shift+w instead of the regular ctrl+shift+z if i remember correctly. There were other shortcut that changed also. I'm not in front of my pro tools but i think i have the 2022.4. And shortcut in my case have changed for sure.
I haven't seen any keyboard shortcuts change for me either moving through 2022.4 and I use TONS of shortcuts.
What happens when you go to Keyboard Shortcuts and choose "<factory default>"?
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
I will check that later when i will be in front of my Pro tools. Thanks for your suggestion.
What keyboard layout do you use? I see that your location is set to France.
I believe that when they introduced the ability to remap keyboard commands they may not have accounted for different layouts. I've seen other users mention remapped shortcuts but I doubt this was the developers' intention. The comma key sits in the same position on a French layout keyboard as the M key would on a US ANSI layout. I suggest opening a support ticket. They may resolve the difference in a future update if enough people complain. |
Bingo Django!
i think you find the issue. I have a french keyboard so an AZERTY layout and actually Pro tools keyboard shortcuts take into consideration a QWERTY layout. I will check if there is not somewhere i can change that otherwise will open that ticket. |
So Dizzi45Z when i choose "factory default", the shortcuts are reset to default but still in the US layout. JingleDjango points out the problem. It's the layout that is wrong. Even if i choose "Follow keyboard layout" some shortcuts became good but not all of them, i think because i have set the language of Pro tools in English. I had PT 12 in English but my keyboard layout was good. So Avid need to make a correction. I would love to only have a patch to correct that and not to upgrade to a new version of Pro tools and take the risk of dealing with other issues again. 2022.4 is rock solid for me: no crashes, no issues.
Edit/change keyboard shortcuts | Thenewexhibit | Pro Tools 12 | 4 | 03-14-2016 09:46 AM |
Change Grid and Nudge Value Shortcuts Not Working | jerosta | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-06-2012 10:51 AM |
Can i change the keyboard shortcuts for nudge | ianlounge | Pro Tools TDM Systems (Mac) | 7 | 02-28-2008 08:28 AM |
Change Bus Mixer Routing Shortcuts | tilman | Pro Tools TDM Systems (Mac) | 6 | 04-01-2007 01:04 PM |
Possible to change shortcuts? | Voxvendor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 09-26-2004 05:38 PM |
