how to paste a clip at identical time marker as original
With PT in slip mode, how do you paste a copied clip at the identical start time as the original clip?
Pro Tools 12.6.1 for Windows 10 ASUS Core i7 3770 Yamaha Steinberg UR 44 Golden Age Project Pre-73 JR Warm Audio WA12 MKII Preamp Glyph 1TB GPT50 external drive - Firewire LaCie 1TB external drive - USB JBL LSR305 monitors AT 2020 & 2021 Equation F.20 condenser mic |
Re: how to paste a clip at identical time marker as original
select the original clip, and hit paste
I guess I need to explain more. Say you've got a clip in the middle of a track (slip mode) and you copy the clip, create another track, and want to paste that clip into the same time location as the original. If you just copy and paste into the new track, it isn't pasting at the same start point as the original. How do you get it to come out in the right position without dragging it sideways and guessing?
Or, if you want to drag a clip to another track but in the same time position, how do you do that in slip mode?
What wwittman described does indeed work to do exactly what you want, but just needs a few more steps. Create a new audio track with same number of channels(mono, stereo, surround) and drag&drop the new clip onto this blank track(anywhere in the timeline, it won't matter). When you drop the clip, highlight it and hit Ctrl-X, which will cut(disappear) and copy to the "clipboard". NOW, click to highlight the clip you wish to replace, and hit Ctrl-V, which will paste it exactly where the original clip started. You will likely figure out some shortcuts to this, I just wanted to give you enough info to dive back in.
Another method would be to highlight the clip you want to replace and copy the start time, then use SPOT mode to paste the new clip at the same starting point.
Thank you! I also just played around with pulling the selection down, duplicating it, and dragging the duplicate back to top, and snap to next. This is getting fun now
And this should do it also : select the clip , C for copy , click the other track name (timeline stays, just the other track is selected) , V for paste.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Why create a new track and paste the clip into it? Just copy the track; the clip comes with it.
-- Mike - HP Spectre x360 Convertible 14t-ea100 - 2.9 GHz (5.0 Max Turbo) i7-1195G7 32GB RAM, OLED 3k x 2k, Iris Xe Onboard Graphics - Windows 11 - PT 2021.12 - PreSonus Quantum 2 - PreSonus Studio 24c - Mackie Onyx 1640i - Samsung T3 and T5 SSDs - Various USB2/3 and Firewire HDDs |
I said that in the name of being more fool-proof than efficient. Copying a track isn't always an option. Once the OP is able to perform what he NEEDS, I bet he will figure out a few ways of being more efficient
start-alt-drag works PERFECT! Thanks!
How to paste a clip without highlighting? | Led | Pro Tools 12 | 1 | 07-19-2016 11:38 PM |
copy paste clip gain | Cryos | Pro Tools 12 | 0 | 03-13-2016 06:39 PM |
Need Help: move the start of a clip on a marker | cmbourget | Windows | 5 | 03-13-2016 06:35 AM |
Editing duplicate clip alters original clip | screename1011011 | Getting Started | 4 | 02-24-2016 07:03 AM |
Ho do I move clip to marker | SimonBosley | Pro Tools 11 | 3 | 02-27-2015 12:39 AM |
