7.4 will not launch...IE8 not installed
This problem has exactly the same symtoms (I've been through it...couldn't get IE8 out of my PC...finally bought a new one!) as the IE8 situation; click on the icon, hour glass....nothing. The PT's exe appears in the task manager but it does not launch. The problem started after I installed trial versions of Abobe CS4 Premiere & Photoshop. Is there a known conflict between these Adobe products and PT's? I uninstalled both programs, did everything else I could think of but no luck.
I am on a PC, XP, IE6. Thanks in advance!! P.S. Is there any wat that IE8 could creep in without being noticed?? How's that for paranoia?? |
Re: 7.4 will not launch...IE8 not installed
Might wanna put a little more info on your system out there.... You have USB hard drives, or firewire?
I'm pretty much illiterate when it comes to the computer end of things....but I have been using PT's for around 7 yrs. It is a Firewire Mbox 2 Pro. What other info should I include? The PC is new basically new...August...so I'm sure I can find specs on my reciept.
Thanks again! |
Ok, Here's the info.
I will uninstall IE6 pronto.... Thank you, you guys are the best!!! SiSoftware Sandra Computer Model : Dell Precision WorkStation T3500 Workgroup : WORKGROUP Host Name : DF86GVH1 User : Mark Processor Model : Intel(R) Xeon(R) CPU W3505 @ 2.53GHz Speed : 2.53GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Integrated Data Cache : 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 4MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 2 threads sharing Computer Mainboard : Dell 0K095G BIOS : Dell A01 03/09/2009 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3GB ECC DIMM DDR3 Chipset Model : Dell X58 I/O Hub Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Chipset Model : Intel Core CPU Generic Non-Core Registers Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Total Memory : 4GB ECC DIMM DDR3 Memory Bus Speed : 2x 532MHz (1GHz) Memory Module(s) Memory Module : Hynix (Hyundai) HMT125U7BFR8C-G7 2GB ECC DIMM DDR3 PC3-8500E DDR3-1066 (7-7-7-20 4-27-8-4) Memory Module : Hynix (Hyundai) HMT125U7BFR8C-G7 2GB ECC DIMM DDR3 PC3-8500E DDR3-1066 (7-7-7-20 4-27-8-4) Video System Video Adapter : NVIDIA Quadro NVS 295 (16 SP 252MHz, 256MB DDR3 2x176MHz, PCIe 2.00 x16) Graphics Processor Storage Devices WDC WD1001FALS-75J7B0 (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 932GB (C:) WDC WD5000AAKS-00TMA0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB (D:) TSSTcorp DVD+/-RW TS-H653G (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:) HCXSPC 9UVK1IFGTY7C (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) : N/A (F:) Logical Storage Devices OS (C:) : 931GB (NTFS) @ WDC WD1001FALS-75J7B0 (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) DRV4_VOL2 (D:) : 466GB (NTFS) @ WDC WD5000AAKS-00TMA0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Optical Drive (E:) : N/A @ TSSTcorp DVD+/-RW TS-H653G (SATA150, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (F:) : N/A @ HCXSPC 9UVK1IFGTY7C (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) Peripherals LPC Hub Controller 1 : Dell LPC Interface Controller LPC Legacy Controller 1 : SMSC SCH5504-NS Audio Device : Dell HD Audio Controller Audio Codec : Analog Devices 194Ah Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : Dell 6 port SATA AHCI Controller USB Controller 1 : Dell USB UHCI Controller #4 USB Controller 2 : Dell USB UHCI Controller #5 USB Controller 3 : Dell USB UHCI Controller #6 USB Controller 4 : Dell USB EHCI Controller #2 USB Controller 5 : Dell USB UHCI Controller #1 USB Controller 6 : Dell USB UHCI Controller #2 USB Controller 7 : Dell USB UHCI Controller #3 USB Controller 8 : Dell USB EHCI Controller #1 FireWire/1394 Controller 1 : Dell FW322/323 IEEE1394 OHCI FireWire Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : Microsoft Office Document Image Writer Driver (300x300, Colour) Printer : HP PSC 1500 series (USB, Colour) Scanners and Cameras Camcorder : Logitech Logitech QuickCam S5500 (Camcorder, USB) Network Services Network Adapter : Broadcom NetXtreme 57xx Gigabit Controller - Packet Scheduler Miniport (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance : x86 |
Anyone? Thanks!
Pro Tools Won't Launch - IE8 not installed | Jody Stevens | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 08-28-2012 05:27 PM |
Strike installed but won't launch in PT 10 | Mac Walter | macOS | 2 | 11-04-2011 05:52 AM |
installed pro tools 8- will not launch? | fenderusa2003 | Pro Tools M-Powered (Win) | 1 | 07-30-2009 07:21 AM |
Installed Logic 8, now PT 7.3 Will Not Launch, Help! | tvtvtv | Pro Tools TDM Systems (Mac) | 6 | 11-17-2007 08:22 PM |
Installed MPT, now protools won't launch. | double | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-20-2007 12:46 PM |
